Old 05-06-2022, 09:15 AM
mtmusic mtmusic is offline
Default Copy/Pasting Text Not Working PT 2022.4
Is anyone else having an issue in which copying and pasting text no longer works in Pro Tools 2022.4? I've modified a couple of keyboard shortcuts, but none of the cut/copy/paste commands... I'm noticing that this doesn't work when I'm trying to copy/paste track titles from one track to the next, and is also not working when I try to copy/paste text from the track comments of one track to another. Now that I'm testing it though, it's not working for markers either, that's just not as much an issue for my workflow as the other two
Anyone else?
Pro Tools Studio 2022.9
macOS Monterey 12.5.1
Macbook Pro 2021, M1 Max, 64GB RAM
Universal Audio Apollo x16 (x3)
Old 05-06-2022, 03:27 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Copy/Pasting Text Not Working PT 2022.4
Well, I’m on Windows and I didn’t modify any key commands, but copy/paste is working fine here. Both on track names and track notes.
Will
System Details
Old 05-07-2022, 06:30 AM
I should clarify, I did try resetting keyboard shortcuts back to default, and the issue is still there. Any other Mac/M1 users having this issue?
Old 05-08-2022, 10:37 AM
matthewstyles matthewstyles is offline
yes getting similar issue here on one computer, control z (undo) changed to Control Y...
running Mojave
Old 05-13-2022, 08:59 AM
Following up one more time on this to say that it appears that paste is working on text for me, but not cut or copy. I thought all three were broken because I was trying to copy/paste track names, but I accidentally just pasted a dropbox link into a track name, having forgotten about this bug. Upon further testing, cut, copy, and paste are all working in other applications as normal. If I copy text from another application like an email or something, I can paste that text into Pro Tools text fields as expected (track names, marker locations, etc). But cut and copy don't work for me on text anywhere in pro tools, even with the keyboard shortcuts set to default. It's also probably worth noting that cmd+c and cmd+x work fine for copying and pasting audio/clips/etc within pro tools
Also for the record, my undo is still cmd+z, not cmd+y, not sure why that would be happening to matthewstyles...
Old 05-19-2022, 03:44 AM
ariaprayogi ariaprayogi is offline
I’m having the same issue, pasting works but copying names doesn’t.
Mojave, PT2022.4
Old 05-20-2022, 03:21 PM
RSLAMBERT RSLAMBERT is offline
Happening for me as well.
Old 05-23-2022, 03:40 PM
JimaSound JimaSound is offline
This happens to me also intermittently on a MBP Max (Monterey {all versions}). Relaunching the Finder by force quitting it seems to fix it for the short term.
Old 05-24-2022, 08:36 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Intermittent here in Mojave 22.4 HDX
IZ focus lit incorrect? Maybe.
Old 05-30-2022, 03:14 PM
Fixed by trashing prefs …all good now.
Copy and pasting yorgo Windows 15 06-04-2014 09:24 AM
Don't copy automation when pasting? kirkbross Pro Tools 11 2 10-23-2013 09:55 AM
copy & pasting from 3/4 to 4/4 krusen MIDI 12 08-01-2007 04:44 AM
Copy,and pasting vocals???? kaotikmuzik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-02-2004 02:55 PM
SYSEX data: pasting text vs. recording from another device EricWillhelm MIDI 8 08-20-2003 11:09 AM
