Old 04-12-2015, 10:50 PM
jgiannis jgiannis is offline
Default Run plugins without installing???
I use PT10 on Mac at work. I do not have administrator permission to install some of my personally-owned plugins (which I use at home on my personal computer). Is there a way to run these plugins on my work computer without installing them? Maybe from a flash drive?
Old 04-12-2015, 11:54 PM
Craig F Craig F is offline
Default Re: Run plugins without installing???
you might be able to drop them into the proper folder but most likely, no that would defeat the purpus of having an Administrator
Thank you,
Craig
Old 04-13-2015, 04:59 AM
In a word - no. For PT to see them they'd have to be in Mac HD/library/Avid/audio/plugins folder for aax plugins and if write permissions are set such that you can't write to the folder then PT won't see the plugins. Not to mention your facility probably has a policy against user supplied flash drives or such as many places do. Violating that could get you fired and don't laugh because that has happened to many people.
Jack
QAPLA!
Old 04-13-2015, 07:58 AM
junkerde junkerde is offline
you cant do that
Old 04-13-2015, 08:33 AM
Question coming from a PC guy; would it be possible for the OP to carry an external drive with the complete OS, Pro Tools and his plugins? Just wondering as I knew that Macs can run from an external system drive
Old 04-13-2015, 09:45 AM
yeah
Old 04-13-2015, 10:16 AM
And for places already worried about people touching things booting a new OS image on a computer is likely to be very unwelcome. It can let you bypass security/access controls on that computer. If you need tools to work and things are holding you back, discuss those issues with your employer. There may be good reasons why they do this, or things you can do to get admin privilages, or possibly get an admin to install the plugins for you (but the downside there is risking destabilizing production systems for all users, or just having lots of junk show up that is not usable), or maybe it's better to bring in a personal laptop, ... or good reasons why you should find some place else to work.
Old 04-13-2015, 11:56 AM
Originally Posted by junkerde View Post
you cant do that
Can't do what? Your answer makes no sense.
Jack
QAPLA!
Old 04-13-2015, 12:00 PM
yeah
Theoretically you could but the drive would have to have the same or newer OSX version as on the machine in question. Not to mention the drivers for all the hardware. And you'd have to have access to the connections for the ports and that's unlikely to go unnoticed by someone, especially if the machine is on a network. Not to mention getting your butt fired from your job. To put it simply - doing this ain't worth losing your job over. You'd be jeopardizing system security as well but that's already been bought up.
Jack
QAPLA!
Old 04-13-2015, 12:49 PM
JFreak's Avatar
JFreak JFreak is offline
Yes and no.
You could install them on a flash drive and then create symbolic links that point to them, but as the plugin library is in /Library you would need to have admin account to create the links.
So yes, if you have admin account -- and no, if you don't have [admin account] there is no way.
Janne
Help installing plugins... clay_vessel777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-22-2007 10:28 PM
installing plugins infamous plague 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-03-2005 11:15 PM
installing plugins aishabag23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-06-2004 02:36 PM
installing plugins? romerom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-12-2004 01:07 PM
installing plugins...... woodbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-10-2004 09:06 AM
