Old 05-12-2009, 11:25 AM
products7074740 products7074740 is offline
Default Floating Cursor Bug
I was wondering if Digi had any comment on this, or if any other users have experienced this. After a fresh OS and PT 8 install I notice that when I drag the edit window down up above it there is a floating cursor from Pro Tools. Sometimes the numbers from the time Bars|Beats ruler is there too. It doesnt seem to be major but i was just wondering if this a known issue.
Here's what I'm working with
MBP 15'' with 10.5.6
PT LE 8.0cs2
Just had one audio track up.
there is is next to the Audio Suite plugin.
Old 05-14-2009, 07:02 AM
Default Re: Floating Cursor Bug
Anyone?
Old 05-14-2009, 07:19 AM
tamasdragon tamasdragon is offline
Never saw this before. Had some strange graphic issues though, but not like this.
Tamas Dragon
my blog:Tamas Dragon
Old 05-14-2009, 12:15 PM
DigiTechSupt's Avatar
I can't necessarily comment about this, but only say that I've seen graphic anomalies on virtually every system I've used (PC or Mac) at one point or another in any number of different apps.
Is it causing problems of any sort? Does it 'stick' there or go away once another graphic element occupies the same space?
Does the same problem occur if you test from a different admin account?
Avid Audio Tech Support
Support FAQ
Old 05-28-2009, 09:23 PM
Hi. I uploaded a picture of this graphical error. it seems to occur usually when i switch to another programs window. Usually reducing the mix window and maximizing it again realigns the ruler.
http://yfrog.com/17picture1codp
Old 05-29-2009, 08:25 AM
easy.sound easy.sound is offline
Hi!
Same problem here!Here are some pictures of the bugs:
Plz Help!!!!!!!
http://www.flickr.com/photos/filete/
Old 05-29-2009, 08:29 AM
Originally Posted by easy.sound View Post
Hi!
Plz Help!!!!!!!
Can you give us your complete system specs so we can try to reproduce this on a similar machine?
Support FAQ
Old 05-29-2009, 09:05 AM
Mainboard : Asus P5N32-SLI-SE-Deluxe
Chipset : nVidia nForce4 SLI X16 Intel Edition
Processor : Intel Core 2 Duo E6600 @ 2400 MHz
Physical Memory : 4096 MB (4 x 1024 DDR2-SDRAM ) (switch 3g)
Video Card : Matrox Parhelia APVe
Hard Disk : WDC (250 GB)
Hard Disk : WD (500 GB)
DVD-Rom Drive : Optiarc DVD RW AD-7173A
DVD-Rom Drive : Generic DVD-ROM SCSI CdRom Device
Monitor Type : Hewlett Packard HP w2408 - 24 inches
Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3
DirectX : Version 9.0c
Projectmix i/o
PT 8 cs2
Please guys HelP
Thanks
Old 05-29-2009, 09:16 AM
irwinmfletcher irwinmfletcher is offline
Same thing here, been happening ever since PT8.0.
Every time I minimize the edit window.
-Fletch
MacPro 8 core/10.5.6/002R/Command8
Old 05-29-2009, 12:13 PM
Model Name: MacBook Pro
Model Identifier: MacBookPro5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP51.0074.B01
SMC Version (system): 1.33f8
Serial Number (system): W8840LAV1G0
Sudden Motion Sensor:
State: Enabled
MAC OS 10.5.7/PT LE 8.0cs3
32 bit floating mikeyman Pro Tools 10 2 01-08-2014 07:15 AM
Pro Tools 10... 32 bit floating??? shamanrock Windows 1 11-22-2011 06:05 AM
Is PT 9 32 floating point ? K Roche Pro Tools 9 6 11-21-2010 08:37 PM
32 bit floating point toadman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 01-11-2007 05:27 PM
32 bit floating point narleysoundz Pro Tools TDM Systems (Mac) 2 09-10-2001 08:25 PM
