Latency problem...
First of all, sorry about my broken English...
I have Core2Duo 6850 3ghz, 4 GB RAM, Pro Tools 8 CS2 instaled on Windows XP and OS X Leopard 10.5.5. On Leopard everything works great, I can put 32 samples latency and my computer still works fine, but on Windows XP I have problem to play virtual instruments with latency less than 256 samples. With 128 samples latency it crackles every 10 seconds, but with 64 samples it crackles every 3 seconds, the same thing is with Nuendo, Cubase, and Kore 2 standalone, or any other standalone VST instrument. |
Re: Latency problem...
Tell us about your computer hardware. Post a Sandra report. Start here.
What PT interface are you using?
I have Digi Rack 002.
SiSoftware Sandra System Host Name : BOJAN User : Bojan Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz Speed : 3.01GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing System System : Gigabyte Technology Co., Ltd. EP35-DS3R Mainboard : Gigabyte Technology Co., Ltd. EP35-DS3R Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Award Software International, Inc. F2 Total Memory : 3.5GB DIMM DDR2 DDR3 Chipset Model : Giga-Byte P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 376MHz (1.50GHz) Total Memory : 4GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 451MHz (902MHz) Memory Module(s) Memory Module : Kingston KTC1G-UDIMM 1GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-5-5-18 3-23-6-3) Memory Module : Kingston KTC1G-UDIMM 1GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-5-5-18 3-23-6-3) Memory Module : Kingston KTC1G-UDIMM 1GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-5-5-18 3-23-6-3) Memory Module : Kingston KTC1G-UDIMM 1GB DIMM DDR2 PC2-6400U DDR2-800 (5.0-5-5-18 3-23-6-3) Video System Adapter : ATI Radeon HD 3600 Series (512MB, PCIe 2.00 x16, PS3.0, VS3.0) Graphics Processor Adapter : ATI Radeon HD 26XX (RV630) (1.03, 512MB, 725MHz/252MHz) Storage Devices Maxtor 6V200E0 204GB (SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 190GB (C:) (F:) WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (D:) WDC WD1600AAJB-00PVA0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 149GB (G:) (H:) TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (J:) STKNEJG 2R89IBO (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (I:) Logical Storage Devices Windows (C:) : 50GB (NTFS) @ Maxtor 6V200E0 204GB (SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Backup (F:) : 140GB (NTFS) @ Maxtor 6V200E0 204GB (SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) Hard Drive (D:) : 298GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Leopard (G:) : 50GB (HFSJ) @ WDC WD1600AAJB-00PVA0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) Mac Drive (H:) : 98GB (HFSJ) @ WDC WD1600AAJB-00PVA0 160GB (ATA100, 3.5", 7200rpm, 8MB Cache) CD-ROM/DVD (J:) : N/A @ TSSTcorp CDDVDW SH-S223F (SATA150, DVD+-RW, CD-RW, 2MB Cache) CD-ROM/DVD (I:) : N/A @ STKNEJG 2R89IBO (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : Giga-Byte (ICH9) LPC Interface Controller Audio Device : Giga-Byte (ICH9) HD Audio Controller Audio Device : Giga-Byte RV635 Audio device [Radeon HD 3600 Series] Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Giga-Byte (ICH9) 4 port Serial ATA Storage Controller 1 Disk Controller : Giga-Byte (ICH9) 2 port Serial ATA Storage Controller 2 Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 2 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 3 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 4 : Giga-Byte (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 6 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 7 : Giga-Byte (ICH9) USB Universal Host Controller USB Controller 8 : Giga-Byte (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : NEC uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr System SMBus Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps) Network Adapter : Hamachi Network Interface (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance : x86 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
You're using XP SP2 with a multi-core processor; have you installed the Microsoft dual-core hotfix?
You might also want to update to SP3.
First of all use the DPC latency checker to get a clear picture.
Gigabyte MBs with early BIOS (yours is F2) suffer from latency spikes. You have to get the latest BIOS which will take care of the latency.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
I'm downloading SP3...
Yes, but I have OS X on the same machine, and everything works fine... |
DPC Latency Problem? | paulrgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 02-17-2009 01:11 AM |
latency problem | mug | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 09-24-2008 09:21 AM |
003 Latency problem | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-06-2007 09:22 PM |
Is this a latency problem? | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-13-2002 12:46 AM |
latency problem | geojack62 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-03-2001 12:12 AM |
