Old 02-03-2005, 02:01 PM
Ward2South Ward2South is offline
Default Possible Power Harness problem with 002r
I think it might be a power harness problem. but it didn't give me multiple clicks. it just sits there with the mute light on. Thoughts?
Old 02-03-2005, 02:22 PM
Default Re: Possible Power Harness problem with 002r
If you're handy, open the box, unplug the power harness, and replug it. Takes a few minutes, and usually wakes it up.
Quad 2.5 G5, 4.5G RAM
Old 02-03-2005, 02:46 PM
What does it look like.
Old 02-03-2005, 03:27 PM
Judging from the question, I'd say call Digidesign.
Old 02-03-2005, 03:33 PM
ZimmerFrei ZimmerFrei is offline
second time for me with the infamous power harness problem.
I tried this:
1. Disconnect the device from power.
2. Open the top cover with the Philips screwdriver.
3. To the right you'll see a power supply unit. Open 4 screws to the right outer side of digi.
4. Using a flat screwdriver by pressing on the edges disconnect the multi connectors (white plastics) coming to and out of power supply unit.
5. Take it out from digi.
6. Get pure alchohol and clean the connectors on both sides (can use ear sticks for it).
7. With a nidle or something like that try to clean female connectors going to the boards and to the power switch.
8. Connect everything back and close the top cover.
it worked fine !
time seems to pass the world happens
002r Firewire Problem; Pretty Sure NOT Power Harness matthewinphilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-28-2009 12:47 PM
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
New Fix for 002R Power Harness Problem tommymandel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-01-2008 08:04 PM
Power harness problem!!! 002r jayq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 08-07-2006 12:09 AM
power harness on 002R chrisk23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2005 11:06 PM
