Old 07-09-2021, 04:50 AM
[email protected] sleshnyc@gmail.com is offline
Default Have you found a useful VI parameter controller?
i'm looking for something to control virtual synths etc. Not to play notes, but to tweak parameters using knobs instead of a mouse. One that would map to falcon or xpand or other third party synths. Something that would enable me to approach them more as the analog devices they model. Has anyone found a reasonble solution.?
Old 07-09-2021, 05:27 AM
Stephen Bond's Avatar
Default Re: Have you found a useful VI parameter controller?
Anything controller with at least 8 controller knobs or faders is a good start. It's pretty to easily assign them these days without looking up MIDI CC numbers and such.
Many plugins have a requisite 8 "quick" knobs which will control the main or important parameters in the plugin synth, sampler etc.
Certainly more fun than mousing around.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 07-09-2021, 07:52 AM
briaboy briaboy is online now
StudioLogic ML Mixface is pretty good.
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
Old 07-09-2021, 09:24 AM
If you have a midi controller with some knobs and sliders, open your VI plugin and right-click on a parameter. If you see an option named "Midi Learn", move a knob or slider on the controller and that should take over the parameter control. Not all VI plugins have this option, but I know DB-33 and MiniGrand have it. Once you get something programed as you like, save the track as a Track Preset so this midi learn stuff will be remembered
Old 08-03-2021, 01:14 PM
massivekerry's Avatar
massivekerry massivekerry is online now
I use a Novation Launch Control XL. It's a little overboard with controls, but I use the faders for Mod/Expression, and a few orchestral-mapped things (like you'll see in Junkie XL's vids), but there are a ton of knobs, as well. I have a row mapped to the standard MIDI CCs for Filter & Cutoff, and another for the standard MIDI CCs for ADSR (or whichever of the ones are standard). I also have a template with softsynths in where I've used "MIDI Learn" (in the VIS that support it) to map a few of my regularly-used controls to some of the knobs, but I've only had success when i save them in the template, so the assignments are recalled each time.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 08-04-2021, 05:01 AM
To go further with this with Falcon unless you're trying to control it's built-in effects parameters nothing else is global. So you'd have to setup each synth/sampler separately. For example - you MIDI learn controls for something in the Avid Plugsound Edition expansion and you go to another expansion - you have to MIDI learn those controls. Master output volume IS global though.
Parameter controls thierryhenry Pro Tools 12 4 01-13-2016 09:17 AM
DIGI AIR FX parameter MIDI mapping for controller BlackKey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2011 02:09 AM
Drehbank for RTAS Softsynth Parameter Controller filosofem MIDI 0 08-09-2006 09:11 PM
Midiman controller not found in OMS menu Dead River Studio MIDI 3 12-05-2001 01:57 AM
Controller can't be found on printer port yin7yang64 Pro Tools TDM Systems (Mac) 1 03-05-2001 12:38 AM
