Code -7 Initialization Error...PLEASE help, Sandra included
Hello all...first time Avid user here, just bought Keystudio with Pro Tools SE to use live for some synth/pad sounds at my church.
Anyways, I followed all the start-up instructions, restarted the CPU...and upon restart, I get a weird black screen that says "Code -7 Initialization Error" along with another box that says something about x86 - I think, I'm going off memory on this part. EDIT: Its similar to the second photo that this guy posted...http://duc.avid.com/showthread.php?t=285290 Okay, post restart...I figured maybe that was nothing, so I clicked the Pro Tools SE icon and the "Code -7" error popped up, followed by a "0xc0000142" application error. I realize some others had posted about this issue before, and I Google searched, tried the search on here, tried calling Avid - I've tried everything before posting to no avail. SO...this is my last resort, I'm really hoping someone can help because I really want to play this in church tomorrow. Here's my Sandra: SiSoftware Sandra ID Host Name : mark-HP Workgroup : WORKGROUP Computer Model : HP Pavilion dv6 Notebook PC 103C_5335KV G=N L=CON B=HP S=PAV Serial Number : 5CH12***** Chassis : HP Notebook Mainboard : HP 358E Serial Number : PBYWL06******* BIOS : HP F.1C 05/12/2011 Total Memory : 3.48GB DDR3 SO-DIMM Processors Processor : AMD A6-3400M APU with Radeon(tm) HD Graphics (4C 1.4GHz/2.3GHz, 667MHz IMC, 4x 1MB L2) Socket/Slot : FS1g1 (µPGA) Chipset Memory Controller : AMD F12 (Llano) APU Root Port 100MHz Memory Controller : AMD F12/14 (Brazos/Llano) APU Root Complex 100MHz, 4GB DDR3 SO-DIMM 1.33GHz 64-bit Memory Module(s) Memory Module : Samsung M471B5273DH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Samsung Generic PnP Monitor (1600x1200, 156AT05-H07 , 15.3") Video Adapter : AMD Radeon(TM) HD 6520G (320 SM5.0 400MHz, 512MB DDR3 1.33GHz 64-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : AMD Radeon(TM) HD 6520G (320SP 4C 400MHz, 256MB DDR3 1.33GHz 64-bit, Integrated Graphics) Compute Shader Processor : AMD Radeon(TM) HD 6520G (320SP 400MHz, 512MB DDR3 1.33GHz 64-bit, Integrated Graphics) Storage Devices TOSHIBA MK6476GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 596GB (C:) (D:) (E:) hp DVD-RAM UJ8B1 (8.4GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (F:) Logical Storage Devices SYSTEM : 199MB (NTFS) Hard Disk (C:) : 581GB (NTFS) @ TOSHIBA MK6476GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) RECOVERY (D:) : 14GB (NTFS) @ TOSHIBA MK6476GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) Hard Disk (E:) : N/A @ TOSHIBA MK6476GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) Pro Tools SE (F:) : 8GB (CDFS) @ hp DVD-RAM UJ8B1 (8.4GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : HP Hudson LPC Bridge LPC Legacy Controller 1 : Winbond W83687THF Audio Device : HP BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series] Audio Codec : ATI (AMD) HDMI Audio Audio Device : HP Hudson Azalia Controller Disk Controller : HP Hudson SATA Controller [AHCI mode] Disk Controller : HP Hudson IDE Controller USB Controller 1 : HP Hudson USB OHCI Controller USB Controller 2 : HP Hudson USB EHCI Controller USB Controller 3 : HP Hudson USB OHCI Controller USB Controller 4 : HP Hudson USB EHCI Controller USB Controller 5 : HP Hudson USB OHCI Controller USB Controller 6 : HP Hudson USB EHCI Controller SMBus/i2c Controller 1 : ATI SB800 SMBus Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : CUSTPDF Writer (4000x4000, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Ralink RT5390 802.11b/g/n WiFi Adapter (802.11n (HT), AES-CCMP, 72Mbps) Power Management Battery No 1 : Hewlett-Packard 5100 55.08Wh/4.46Ah Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.5 Thanks in advance, I hope I followed all of the procedures properly... Jordan |
Re: Code -7 Initialization Error...PLEASE help, Sandra included
Have you tried to uninstall and reinstall Pro Tools SE? There are utilities like "Revo uninstaller" that will make sure the application is completely removed one can find it in Google.
Less programs that run in the background the better, so anti virus etc should be closed. Initialization means that the error occurred when the program was loading (starting up). Make sure your device is connected. With your PC specs Pro Tools SE should run fine. |
...another error code -7. I have the same problem... see my post from earlier this week. But none of the posts show any resolution. Did you get it fixed? How? Thanks!!
Hi : I also have the same problem and , checking the dates of the posts I think that the problem is related with some windows update. Ive tried to re install PT 7.4, even without updates (cs3 and the like) but no way. And is curious that PT doesnt have a "launch time" and then appears the curse of the code -7: as soon as you launch it pops out!!!-
Thank You |
Code: -7 (Initialization Error) | JasonJN | Windows | 2 | 09-03-2013 04:02 PM |
What does Initialization Error Code: -7 do? | 6speedhemi | Windows | 2 | 04-05-2013 09:16 PM |
Initialization Error Code: -7 Help! | cmeier7 | Pro Tools M-Powered (Win) | 0 | 02-07-2013 10:58 PM |
Initialization error code: -7 | lubs7705 | Windows | 2 | 10-12-2012 08:49 PM |
New i7 build 6068 error Sandra included | jcolagross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 07-10-2010 06:36 PM |
