Old 02-26-2010, 12:06 PM
tonwurm's Avatar
tonwurm tonwurm is offline
Default Re: Loop Playback Not Working
loop-playback works fine with quickpunch activated, but if then a track is record armed, loop-playback is disabled
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 02-26-2010, 12:15 PM
Nathan W. Nathan W. is offline
Yeah I don't work on music, work in television post. Hardly ever use loop playback though, love track punch for voiceovers, love the ability to drag the handle out if you missed a punch or slightly clipped something. Saves your butt. I think it IS confusing though that you can go into the "mode" without it working. There's probably a reason for it just can't think of it right now.
Old 02-26-2010, 12:23 PM
Drew Mazurek's Avatar
Of course because without a track armed QP isn't doing anything. I was assuming that a track was armed, my bad.
Trackpunch is like QP on steroids, in that it is recording even for tracks that aren't armed. To fix a bad punch you needn't be in TP, just QP will do. TP is usually only used on rigs acting as dubbers AFAIK.
www.drewmazurek.com
Old 02-26-2010, 01:44 PM
JNS JNS is offline
I was checking Loop Playback on 8.0.3 yesterday and noticed that if I highlighted a region to loop that if I hit the spacebar to start it would de-select my highlighted region and would not do loop playback. If I clicked the "PLAY" button instead of using the spacebar it worked just fine and looped the highlighted region. Is this normal? I usually never use Loop Playback so wasn't sure.
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Old 02-27-2010, 11:51 AM
Danny Caccavo Danny Caccavo is offline
Originally Posted by Nathan W. View Post
Sorry for the posts: Figured it out, it's TRACK PUNCH MODE, does NOT allow you to loop playback. THAT's confusing. When going into track punch mode they should disable loop playback mode in future versions of ProTools or at least provide some indicator so you know loop playback isn't broken. lol
No - please don't start forcing disabling of loop playback mode. Just grey it out if it's not available......don't force the user to change modes!
  #16
Old 08-12-2021, 10:49 AM
widosub widosub is offline
Originally Posted by formfunction View Post
Are any of your tracks record armed? this cancels loop playback. ff
Thank you so much. I've had the same issue.
Loop playback not working since my 9.0.3 update notrude55 macOS 9 02-24-2012 09:40 PM
Loop playback not working? IVcrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-25-2010 02:07 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
About loop playback stevegalante Tips & Tricks 4 09-22-2000 12:57 AM
