SOLVED issue with 9073 error on scrub
i tried to import everything into a clean known good template
that did not work so i used the ProTools Pref and Data Base Helper probably should routinely use this more often (must remember to re set autosave setting later) checked the first six boxes on the left and all was better before the fix: the session causing problems had automation written on every parameter of every track incl auxes and i cleaned off all of it i could by hand one at a time a time waster for sure but what do you do? scrub now works in this session without 9073 errors hurray! the unique thing about this session over most i do was that i imported some tracks that were recording in logic that the client wanted me to ref what that the problem?
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Ctrl+Scrub Wheel issue | kptkarl | ICON & C|24 | 6 | 11-03-2011 04:51 PM |
Pro Tools Scrub/Sync Issue | unstruck | Pro Tools TDM Systems (Mac) | 1 | 08-19-2011 02:24 PM |
I Finally Solved my -9073 Error | Thirsch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-11-2010 02:44 PM |
Access Violation error issue solved | daeron80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-11-2006 03:52 PM |
Serious scrub issue | Compression Records | Pro Tools TDM Systems (Mac) | 4 | 05-19-2005 07:35 AM |
