Key command to name adjacent regions in PT8?
Does anyone know the key command to name adjacent regions on a single track without having to close the naming window. I want to name regions similar to the way I can name tracks(Command+ Right/left arrow). I swear I saw someone use this command, but I'm pretty sure he was using 7.4; definitely not PT8. I can't remember or figure it out
P.S - Im pretty sure it's not in the key commands guide - if it is please lead me to it because I can't find it there. Thanks |
Re: Key command to name adjacent regions in PT8?
2.) Cmd + Shift + R 3.) Rename Region 4.) Enter / Return 5.) Ctrl Tab Continue with steps 2.) - 5.) Basically you need the shortcut for renaming (Cmd+[bleep][bleep][bleep][bleep]+R) and the shortcut for selecting the next region (Cntrl + Tab) Obviously selecting the previous region is Ctrl + Option + Tab. If you need to move around in the edit window, use following shortcuts: P - move up ; - move down Hope this helps, Timothy |
Thanks though |
try selecting multiple regions, and hitting command shift r.
this will jump through all the regions only drag is i'm not sure how it determines the order. it doesn't seem to be timeline position. edit: The order it cycles follows your region bin sorting.
-Evan |
Thanks so much!!!!! This is defiantly my new work flow. I Knew I wasn't dreaming. You just saved me a lot of time. Thank You
Definitely will use that way of renaming. Why the heck I never tried this before I don't know? Cheers, Timothy |
Key command to de-select regions previous and next regions? | jkuehlin | Pro Tools 10 | 1 | 08-03-2013 06:52 AM |
Key command to name adjacent regions in PT8 | djmendoja | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-26-2009 08:32 PM |
When I select a region adjacent regions are also! | potex | Tips & Tricks | 2 | 12-27-2006 11:12 AM |
Superbasic q selecting non-adjacent regions | Karl Engel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-05-2006 01:01 AM |
Volume automation in adjacent regions | pbjnus | Pro Tools TDM Systems (Mac) | 0 | 10-05-2004 03:33 PM |
