Old 12-09-2009, 05:06 AM
Sonic Nomad Sonic Nomad is offline
Default Key Command: Snap Region To Previous?
Hi
I'm working on several projects that require the recording of short phrases. These then need to have a silence of 4 sec inserted and between each phrase.
So I firstly use Strip Silence and then paste a 4sec region between each phrase.
With shuffle mode activated I can simply click on the region and drag it to the previous region and so on.
Problem is this is tedious when you have 180 phrases.
A nice feature in Pr Tools is the "Snap To Previous" found by right clicking on a region. However there does not seem to be a ket command for this, unless I'm overlooking this.
Any ideas?
Old 12-09-2009, 06:37 AM
Default Re: Key Command: Snap Region To Previous?
With Tab to Transient OFF and in SHUFFLE mode, you could tab to the end of the first region, gold the shift key and tab to the beginning of the next region(which would highlight the blank area), hitting DELETE would snap the second region to the end of the first region (but it would also MOVE every region past there by the same amount).
Old 01-19-2010, 12:26 PM
msawitzke msawitzke is offline
You can make custom key commands in System Preferences, Keyboard, Keyboard shortcuts. I've done this to toggle Low Latency mode, etc.
Old 01-19-2010, 12:28 PM
guitar486 guitar486 is offline
I doubt you can access the right click menu's from Keyboard Shortcuts or Quickeys. You may be SOL on this one unless Avid decides to implement it.
----I was thinking of taking a solo in the bridge.
-Nah, I don't think that would sound good.
----Ok, well how about just a series of cool riffs?
Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK
Old 01-19-2010, 12:31 PM
It isn't just a Right Click menu option. It also exits in the Edit menu, so Keyboard shortcuts would work...
Old 01-24-2010, 05:23 AM
5up3rb 5up3rb is offline
I got serious problems trying to find the place you are talking about in the system preferences. I am working the LE, and I don't think you can customize your own key commands here. Haven't found it anywhere.
Mac OS X 10.5.8, iMac 2.66 GHz Intel Core 2 Duo, 2 GB 800 MHz DDR2 SDRAM, Pro Tools LE 8.0.1, Digi Rack 003
Old 01-25-2010, 12:04 AM
tamasdragon tamasdragon is offline
It is not inside le, but in the system preferences of the os.
System preferences/keyboard menu. You can define/refine shorcuts there.
my blog:Tamas Dragon
Old 01-31-2010, 02:53 PM
Thank you tamasdragon, but if you have done it maybe you could help me. I have tried to create a keyboard command for opening VocAlign, but I must be doing something wrong because it doesn't work. Can you walk me through the steps? I would really appreciate if you could...
Shortcut help - snap to previous / next? Jakob Clemen Tips & Tricks 4 03-16-2016 02:13 PM
Snap To Next/Previous QuikCommand? ccanigs2 Tips & Tricks 6 09-21-2013 03:15 AM
snap end of region to grid? pinnacle Pro Tools 10 3 09-10-2012 05:46 AM
Keyboard Shortcut Request: Snap to Previous / Next neotone1 Pro Tools 9 1 12-02-2010 08:07 AM
PT7.3 - snap to next / previous key command? Mark Dann Pro Tools TDM Systems (Mac) 3 10-24-2007 04:22 AM
