Timestamp out of range
I'm trying to spot stereo interleaved BWF files into PT but getting errors. The files show correct timecode in the Workspace: http://www.staczek.net/shots/workspace.jpg The session is set up so that timecode should be in range: http://www.staczek.net/shots/setup.jpg When I try to drag in spot mode, I get this: http://www.staczek.net/shots/error.jpg How is the original time stamp out of range? Can PT not import stereo interleaved BWF files? Does the convert to mono lose the timecode information somehow? These files were exported from Nuendo and spot right back into Nuendo correctly. Thanks, Jason |
Hi.
Check, in prefs, the edit window length. Also, try dragging the files into the edit window in slip mode, then switch to spot & move the audio with grabber. Click "original time stamp". ~ Mac Pro 8 core - clover - 10.5.8 / HD5 / Pro Tools 8.0.1cs2 / Magma PE6R4 / ProControl 24 faders ~ . . ~ MBP 2.66 Intel Core i7 / oo2 / Mbox 2 / Micro / Command 8 / Pro Tools 9.0.1 ~
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Re: Timestamp out of range
Anyone else experiencing this? I've also noticed that drag into the edit window in PT9 takes forever. Several minutes of spinning beach ball before a short clip appears. Using Import | Audio is nearly instantaneous. Why different? Something broken in PT9? Jason |
Hello,
I am bringing this topic back up because I am having the same issue. I have followed the steps regarding using slip mode and then SPOT but it did not work, I am not clear on how I should set the EDIT windows standard length? the files I have comes from a couple of JoeCos and they are BWF. they spot perfectly in nuendo but protools says out of range. the original time stamp of the files starts at abour 21.00 hours. any suggestions? Best, Mattia. |
Bump.
Anybody? Thanks, Mattia. |
So set your session length to , say, 3 hours. Session start at say 20:00 hours.
Pull your files in, set tool to grabber, edit window to spot. Grab a file / region select "original time stamp". And all should be good .
I would guess it has to do with the files being interleaved and versions before 10 only using split flies in the Timeline
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Hello guys, I am using all mono files, no intereleaved. PT8 does not allow to import stereo interleaved files.
thank you priorytools,how do I set my session length to a specific length? Best, Mattia. |
Just to clarify, you can import interleaved files, PT will just convert them to split stereo.
Session length; go into your session set up ( cmd 2 on number keypad ). Set your session start time. . Go into PT pref's / display/ "Edit window default length". It's also a good idea to; PT Pref's / operation / "open-ended Record Allocation". . Set a time period. . obviously a long enough time period to cover the gig etc .
Hi Priorytools,
got it, thank you very much! Mattia. |
Timestamp oddity or bug | Chris Erlon | Pro Tools TDM Systems (Mac) | 1 | 10-25-2006 11:32 AM |
TimeStamp "Out Of Range"... | O.G. Killa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-15-2005 08:20 PM |
Timestamp support? | Peterjk | MIDI | 9 | 03-07-2003 03:51 PM |
original timestamp? | Dopamine | Tips & Tricks | 1 | 06-23-2002 06:18 PM |
Timestamp Weirdness PT5.1.1 | barden | Tips & Tricks | 2 | 06-21-2002 04:35 PM |
