Old 04-02-2009, 05:50 AM
sc0ttkclark sc0ttkclark is offline
Unhappy Tried everything, can't get Pro Tools to Appear after Opening
I used to be able to open up Pro Tools LE fine, but it's no longer opening up.
Here's what's happening:
1. I double-click the Pro Tools LE icon (or anywhere else this icon is and even tried the .exe directly)
2. The ProToolsLE.exe appears in my Processes in Task Manager
3. Pro Tools LE never appears to actually open for me to use, it just stays in the background forever until I end the process.
Here's what I've tried:
1. I've tried completely uninstalling Pro Tools LE and reinstalling - still not working
2. I've tried updating to cs9, it finishes - still not working
3. I've tried following all of the instructions to optimize the XP OS (startups / services) - still not working
4. I've tried to "repair" the installation - still not working
5. I've tried Tech Support Utility.exe and every option it offers - still not working
Can someone help me out? I worked on this all night last night when I should have been laying down some razor sharp chords
Old 04-02-2009, 05:53 AM
Question Re: Tried everything, can't get Pro Tools to Appear after Opening
This might help, here's the Pro Tools Version List.txt that the Tech Support Utility.exe created for me:
Code:
Version List as of Thu 04/02/2009  7:51:38.62
Pro Tools Version
W32i   APP ENU       7.4.0.333 shp protoolsle.exe
Plug-In Versions
	c:\program files\common files\digidesign\dae\plug-ins\*.*
W32i   DLL ENU       7.4.0.168 shp bf essential clip remover.dpm
   -   -   -               -   - bf essential clip remover.dpm.rsr
W32i   DLL ENU       7.4.0.168 shp bf essential correlation.dpm
   -   -   -               -   - bf essential correlation.dpm.rsr
W32i   DLL ENU       7.4.0.168 shp bf essential meter bridge.dpm
   -   -   -               -   - bf essential meter bridge.dpm.rsr
W32i   DLL ENU       7.4.0.168 shp bf essential noise meter.dpm
   -   -   -               -   - bf essential noise meter.dpm.rsr
W32i   DLL ENU       7.4.0.290 shp bf essential tuner.dpm
   -   -   -               -   - bf essential tuner.dpm.rsr
W32i   DLL ENU       7.4.0.168 shp bombfactory bf76.dpm
   -   -   -               -   - bombfactory bf76.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp chorus.dpm
   -   -   -               -   - chorus.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp click.dpm
   -   -   -               -   - click.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp d-verb.dpm
   -   -   -               -   - d-verb.dpm.rsr
W32i   DLL ENU       7.4.0.332 shp digirewire.dpm
   -   -   -               -   - digirewire.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp dither.dpm
   -   -   -               -   - dither.dpm.rsr
W32i   DLL ENU       7.4.0.315 shp dynamics iii.dpm
   -   -   -               -   - dynamics iii.dpm.rsr
W32i   DLL ENU       7.4.0.309 shp elastic audio.dpm
   -   -   -               -   - elastic audio.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp eq iii.dpm
   -   -   -               -   - eq iii.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp flanger.dpm
   -   -   -               -   - flanger.dpm.rsr
W32i   DLL ENU       7.4.0.168 shp funk logic mastererizer.dpm
   -   -   -               -   - funk logic mastererizer.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp invert-duplicate.dpm
   -   -   -               -   - invert-duplicate.dpm.rsr
W32i   LIB ENU       1.0.0.375 shp izotope_radius_win32.dll
W32i   DLL ENU       7.3.0.117 shp mod delay ii.dpm
   -   -   -               -   - mod delay ii.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp multi-tap delay.dpm
   -   -   -               -   - multi-tap delay.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp normalize-gain change.dpm
   -   -   -               -   - normalize-gain change.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp ping-pong delay.dpm
   -   -   -               -   - ping-pong delay.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp reverse-dc removal.dpm
   -   -   -               -   - reverse-dc removal.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp signal generator.dpm
   -   -   -               -   - signal generator.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp signaltools.dpm
   -   -   -               -   - signaltools.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp time comp-exp-pitch shift.dpm
   -   -   -               -   - time comp-exp-pitch shift.dpm.rsr
W32i   DLL ENU       7.4.0.270 shp time shift.dpm
   -   -   -               -   - time shift.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp timeadjuster.dpm
   -   -   -               -   - timeadjuster.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp trim.dpm
   -   -   -               -   - trim.dpm.rsr
Plug-Ins (Unused) Versions
	c:\program files\common files\digidesign\dae\plug-ins (unused)\*.*
W32i   DLL ENU       7.3.0.117 shp dynamics ii.dpm
   -   -   -               -   - dynamics ii.dpm.rsr
W32i   DLL ENU       7.3.0.117 shp eq ii.dpm
   -   -   -               -   - eq ii.dpm.rsr
   -   -   -               -   - [plug-ins (unlicensed)]
   -   -   -               -   - [toolkits]
	c:\program files\common files\digidesign\dae\plug-ins (unused)\plug-ins (unlicensed)\*.*
W32i   DLL ENU       7.4.0.168 shp fairchild 660.dpm
   -   -   -               -   - fairchild 660.dpm.rsr
W32i   DLL ENU       7.4.0.168 shp fairchild 670.dpm
   -   -   -               -   - fairchild 670.dpm.rsr
W32i   DLL ENU       7.4.0.192 shp tl space.dpm
   -   -   -               -   - tl space.dpm.rsr
Music Production Toolkit is not installed.
DV Toolkit 2 is not installed.
Digitranslator
W32i   DLL ENU       7.4.0.309 shp omf.dll
DV Toolkit 1 is not installed.
Old 04-02-2009, 06:08 AM
Unhappy Re: Tried everything, can't get Pro Tools to Appear after Opening
I saw the common files folder there in my last version list, so I uninstalled again and deleted that folder in hopes it was a plug-in that was causing the issue - still not working
Code:
Version List as of Thu 04/02/2009  8:07:15.68
Pro Tools Version
W32i   APP ENU       7.4.0.309 shp protoolsle.exe
Plug-In Versions
W32i   DLL ENU       7.4.0.309 shp digirewire.dpm
W32i   DLL ENU       7.4.0.179 shp dynamics iii.dpm
Digitranslator
Old 04-02-2009, 06:09 AM
phobia phobia is offline
Default Re: Tried everything, can't get Pro Tools to Appear after Opening
Originally Posted by sc0ttkclark View Post
/* snip */
3.Pro Tools LE never appears to actually open for me to use, it just stays in the background forever until I end the process.
/* snip */
How long is "forever" ? I've seen this on a remote installation but eventually the GUI turned up - was related to some services or network related processes (if I remember correctly) that needed to finish before the PT process got attention to finish loading.
Digi 002
Mbox 1
Digi001 (retired to shelf)
Asus P5K Premium v3, Q6600, 2x2GB Corsair
Tyan Thunder n3600B (S2927A2NRF)
2xAMD OPTERON 2214 2.2GHZ
Win XP Pro SP3
Old 04-02-2009, 06:11 AM
Red face Re: Tried everything, can't get Pro Tools to Appear after Opening
Good question, I'm going to leave it running and head to work. I'll remote in periodically today to see if it ever shows it's face.
Old 04-02-2009, 07:04 AM
Nothing yet, it's been nearly an hour. I'm pretty sure it shouldn't take this long. This has also happened btw on a very limited boot (with no startups or non-ms services running) so it doesn't look like it's interference from other programs.
Old 04-02-2009, 07:11 AM
ok - seems to be something else then.
If I think of something I'll chime in later. I guess going through the troubleshooting threads in the sticky section is a place to start as well - then lots of people here usually can assist in more detail, when knowing what's been done and not.
Cheers,
- J
Digi 002
Mbox 1
Win XP Pro SP3
Old 04-02-2009, 07:12 AM
WATYF WATYF is offline
This will most likely fix it:
Delete your cookies folder (the whole folder, not just the files in it). More specifically, you need to get rid of your index.dat file in your cookies folder.
Why? Because PT is a poorly written piece of crap.
P.S. It may not allow you to delete it (because it'll say it's already in use), and if that's the case, then you'll have to get one of those small apps that allows you to delete a file on reboot.
If this indeed ends up solving your problem, you can take heart in the fact that the problem is going to come back every few months or so, and you'll have to delete it all over again.
WATYF
Old 04-02-2009, 08:52 AM
DigiTechSupt's Avatar
Did you possibly install Internet Explorer 8? If so, you should probably try uninstalling it and see if you're able to launch again. We have numerous reports of IE8 causing Pro Tools to no longer launch - we're looking into the cause but for the moment the only solution is to revert back to a previous version of IE.
Avid Audio Tech Support
Support FAQ
Old 04-02-2009, 09:49 AM
sw rec sw rec is offline
"Because PT is a poorly written piece of crap."
Sorry, I HAVE to chime in here. I'm running PT with an 002 Rack on a PC I built two years ago (which makes it obsolete by current standards) and it works. EVERY TIME. I would wager there are THOUSANDS of us who come to work every day and generate actual INCOME on this "poorly written piece of crap." Maybe this lends credence to the old statement that "You don't get what you want, you get what you picture..."
Now I'll step off my soapbox and ask for a sandra report, and ask for you to tell us which version of PT (I'm guessing 7.4 since you just got cs9) and what interface?
Problem Opening Pro Tools 10 Files in Pro Tools 9 kat768 macOS 1 10-20-2012 03:57 PM
Pro Tools 9 asking for iLok authorisation upon opening Pro Tools jimmycolla macOS 0 05-13-2012 11:17 PM
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system rhodamorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-21-2010 05:31 PM
Pro-Tools Not Opening one38productions Pro Tools TDM Systems (Mac) 4 09-05-2007 11:56 AM
i need help opening pro tools Please!!!1 LionHeart1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-13-2006 11:47 AM
