Old 10-02-2017, 02:08 PM
Ailin Gong Ailin Gong is offline
Default Re: How to separately write the compressor and EQ in channelstrip?
Originally Posted by ViTheVault View Post
Hello Ailin,
Your question is not really clear.
"Write" an automation means that you move the knobs (eq or comp) while the song plays... Then you can choose to write till end of selection or till end (if no selection)...
But if you mean to copy paste only the eq. For example: you should open all the automated drop down lanes that you want to copy; from a specific track and paste them in another place in the timeline or on another track where you have the same layout of the automation lanes...
And of course in protools you have many ways to do things...
You can turn of the compressor of channelstrip and save a preset then open it in another instance of channelstrip and write the new parameters...
If you are on HD with latch prime enabled.
You can capture a state by only touching the parameter you want to record and then copy them wherever you want...
I dunno if all this make sense... Or if it answers your question... But hey...
I had to try...
Sent from my SM-G900H using Tapatalk
Thank you!
SSL Deunde Native Bus Compressor and Channelstrip nikhilmulay Buy & Sell 6 07-15-2016 02:01 AM
Consolidating Regions Separately ? Intersound Tips & Tricks 3 04-08-2009 09:16 AM
can LE run without digi 001? is LE available separately? devoid2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-16-2003 05:46 AM
PT LE purchase separately?? whosmatt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-07-2001 04:15 PM
Suggestions - Budget Pre/Compressor ChannelStrip Count Zero Tips & Tricks 4 09-04-2000 10:08 PM
