  #281
Old 03-26-2009, 11:02 AM
TOM@METRO's Avatar
Default Re: Play/Pause issue driving me nuts...
Originally Posted by Keybeeetsss View Post
Seriously sucks; Digi??? Do ya'll see this or not??? Thank goodness I haven't lost any due to this but I'm sure @ any moment it can happen...
The only thing that has saved me with clients is to immediately consolidate the session, delete unused files and do a “save session in" with files and all.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #282
Old 03-26-2009, 11:10 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Still major suckage; although it doesn't happen with me a lottt, still when it does, its just makes u wanna chunk som'n...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
  #283
Old 03-26-2009, 12:48 PM
TOM@METRO's Avatar
YEA, not sexy.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #284
Old 03-27-2009, 04:46 AM
phobia phobia is offline
Yes, it is not a missing feature that can be worked around.
It is an energy thief that takes all fun out of any fun when it kicks in ... And motivational creativity
Digi 002
Mbox 1
Digi001 (retired to shelf)
Asus P5K Premium v3, Q6600, 2x2GB Corsair
Tyan Thunder n3600B (S2927A2NRF)
2xAMD OPTERON 2214 2.2GHZ
Win XP Pro SP3
  #285
Old 03-27-2009, 10:20 AM
TOM@METRO's Avatar
Usually I can work around this issue. Last night was a tough one for me. The only workaround on this session that would keep the client here was a competitors DAW.
Very sad.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #286
Old 03-27-2009, 10:42 AM
Greg B Greg B is offline
I dread coming to the DUC periodically to check on this issue. I got PT in 2004, and read of the issue then, but didn't suffer under 6.4, with the exception of perhaps two times. I built two identical machines, one for me and one for my colleague. We have the same machines as back then, and we're both at 7.1, but I have the problem and he doesn't.
Then the problem began for me in 6.7.
I began to suspect the Quicktime upgrade (degrade) and its stuttering, and eventually reinstalled the old Quicktime, which helped a little. This problem is so widespread across platforms, versions and hardware that I doubt there will be a solution, and that is confirmed every time I check on it.
This problem is caused essentially by having the computer powered up and PT running. I'd hate to be responsible for fixing a problem like that.
When this buzzkill rears its ugly head, the only solution I've come up with is to hold down the talkback button so the artist can hear the soothing sonic of the spacebar, number 3, F12, or HUI controller clicking with a soft reverb tail...
Deepest sympathies to all who have to live with this.
002R Win7, no PT
GigaByte 970A-UD3/AMD FX(tm)-8120
8GB DIMM DDR3
AMD Radeon HD 6570
2 WDC WD10EURX-63FH1Y0
www.soundchasm.com
  #287
Old 03-27-2009, 02:21 PM
TOM@METRO's Avatar
Since installing PT8 this has gone from an annoyance to a nightmare. PT8 has features we would like to keep but for the first time I’m really questioning our faith that clients will stand for much more of this.
Perhaps we could share info on 3rd party plug-ins to see if there is a common thread here.
This is not good.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #288
Old 03-27-2009, 05:22 PM
The Weed's Avatar
The Weed The Weed is offline
Just one of the (many) reasons I went back to 7.3.1cs7.
As a side note, when this is happening, open up your Region List and, if you're in Record and trying to record, see if there is a new Region created in the Region List every time you hit "3" or "F12". I have found that occasionally instead of just the cursor in place I will have inadvertently created a very tiny highlighted region with the cursor and the record head or the play head moves and stops the length of the highlight. Just clicking the Cursor into place obvioulsy gets rid of that. I'm not saying by any means that this is the issue, I'm just saying it may be the case a very, very small fraction of the time.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #289
Old 03-27-2009, 07:51 PM
TOM@METRO's Avatar
Good advice, but not the issue. I wish it was.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #290
Old 03-27-2009, 07:57 PM
TOM@METRO's Avatar
At this time I would like to extend an open invitation to any or all of the PT programmers to come down to my studio here in LA. I will personally pick you up at the airport and let you play with my system all day if you can't duplicate this problem in house. There will be food, girls and beer if you are so inclined.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Pro Tools 11 Play-Pause Issue ProdGawd Windows 7 12-12-2013 05:22 PM
PLAY / PAUSE - Issue ... Once More !!! Zergei Pro Tools M-Powered (Win) 2 12-27-2009 11:50 AM
Some info on the Play Pause Issue Fastermouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-31-2009 05:18 PM
Play/Pause Issue Resolved - Maybe? Try This. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 167 06-20-2009 08:42 PM
cursor issue driving me nuts!! stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2006 03:21 AM
