Source-Nexus vs Source-Connect Standard ???
I've got a source connect VO session on Tues. I'll be doing mono 48k to/from one connection. I installed a 14-day trial of "Source-Connect Standard 3.8" for Windows. It seems to be working with Pro Tools, but I'll know for sure on Monday when I test-connect with somebody.
Question: Should I have gotten "Source-Nexus 1.3" instead of "Source-Connect Standard 3.8"? What's the difference? Which should I get? Thanks!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Re: Source-Nexus vs Source-Connect Standard ???
Source-Nexus and Source Connect are two completely different product that work congruently but you cannot use Source-Nexus as a substitute for Source-Connect..
If you’re connecting with another party using Source-Connect, Source-Connect is what you want and need. |
Source Nexus is like a virtual audio device for routing your audio from inside pro tools to other programs such as zoom, and receiving audio back form them. We use it if we are doing a session, either in our booth or to remote talent on source connect, and a client wants to listen in/ direct form a remote location.. you use nexus as the input and output of zoom instead of a mic and speakers. You put Nexus over an aux track and send the talent and your talkback to it and the output from zoom comes out the aux channel in pro tools.
The audio quality is still dependent on the other program, so zoom still sounds like zoom. You can use source connect now with nexus for higher quality 'listen ins' but the person joining in needs Chrome browser. In theory you could use Source connect now and Nexus to record in pro tools, but I've never tried it, we just use Source connect. |
Just to note, you cannot use Source-Connect Now to connect to someone using Source-Connect. Again, these are two different utilities. They offer similar functionality but do not work together.
If you are an engineer, my advise is to get Source Connect Pro. Otherwise if something happens on the connection, you loose files. Also if you are just talent, then I know a lot of people are fine using the Standard Source Connect with no problems.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
I have worked with a studio that used Source-Connect NOW to record me at their end, but I wouldn't recommend it. Personally, for the best audio from a producer remoting in to direct the session, I would recommend Zencastr.
I did some Source-Connect remote stuff a while back and getting everything to work smoothly was enough trouble that I ended up running it on a separate laptop running its own audio interface that I fed as if it were one of my headphone mixes
I always recommend using Source-Connect "standalone" rather than using it as a plug-in. Fortunately I can use TotalMix to route Sends from Pro Tools to Source-Connect outside of Pro Tools, hence the term "standalone".
I started doing it this way when using the plug-in caused intermittent squeaks and squawks in the incoming signal from the remote studio. Luckily not in my audio going to the remote studio. I'm on Windows and Source-Elements Support said they had a fix for the issue in the next release, but that's been waiting in the wings for a few years. In the meantime they suggested purchasing a separate interface as albee does. Not in the budget, so I learned the alternative I described.
Source Connect’s tech support is outstanding! I wrestled with it on my Windows system, got ghosted by some well-known supposed “audio guru” (which tells me he had no idea how to make it work with Pro Tools on Windows in the first place.) One e-mail to SC tech support, I got a call within minutes, and she had me up and running in no time. Culprit: besides Pro Tools not liking to share hardware, neither, it seems, does a UA Apollo 8. So, all my Source Connect goes both directions thru a Focusrite Scarlett 2i2. Works beautifully.
Yeah we're on Mac, but I use the link plugin all the time and it works flawlessly.
Source Elements releases Windows version of Source-Nexus | sourceelements | Partner Announcements | 0 | 01-31-2022 08:21 AM |
Source Connect Nexus or similar for PC? | Scott G | Post - Surround - Video | 4 | 11-02-2021 06:17 AM |
Sale: Source Elements' Source Nexus Basic and Pro | SoundByLaura | Buy & Sell | 1 | 01-01-2017 08:30 PM |
Source-Connect Standard 3.7 For Sale | reggelitorna | Buy & Sell | 3 | 02-16-2014 10:24 AM |
Source ZIP- a new nifty utility from those Source Connect People | MIKEROPHONICS | Pro Tools TDM Systems (Mac) | 0 | 01-13-2010 09:05 AM |
