Selecting start of clip with Smart Tool
Hello,
I'm noticing that it's a little tricky to select the start of a clip while the Smart tool is selected because the tool always wants to either be a fader tool or a trimmer tool unless I zoom in quite a bit first. Is there some modifier key I should be holding down in order to ensure that the tool stays as the selector tool while at the start of the clip if desired? If not, then I suppose my options are to either switch to the Selector-only tool first before selecting (and then switching back to Smart tool after, which seems a little tedious), select somewhere a little further in from the start and then use Nudge backwards, or I must zoom in first before trying to select the near start of my clip, which also seems a little tedious. The first option isn't too terrible since the middle mouse button shortcut switches between the tools pretty quickly of course, but the less necessary button clicks for me, the better. Thanks in advance! |
Re: Selecting start of clip with Smart Tool
Are you using the keyboard shortcuts and memory locations? Those can really help your work flow. The F6,F7,F8 keys select the SMART tool and the individual tools fast and easy. Then using memory location markers and the numeric keypad(assuming a standard sized keyboard) can get you anywhere in the song quickly with a few key strokes. If these are strange to you, check out some tutorials on youtube
I'm guessing then that there is no real way to prevent the cursor from automatically turning into the trimmer / fader tool if I'm using the Smart tool and am not sufficiently zoomed in enough. I guess I'll keep going about zooming and/or nudging and/or switching tools repeatedly |
fade tool disappeared from smart tool | RobinWinjil | Pro Tools 10 | 5 | 06-25-2020 12:50 AM |
Weird Smart Tool/Selector Tool issue? | Marsdy | Pro Tools TDM Systems (Mac) | 11 | 01-15-2012 07:22 AM |
Get Grabber tool (Object) as part of smart tool? | buckaroo | Pro Tools TDM Systems (Mac) | 8 | 07-13-2010 04:21 AM |
If the "smart tool" was really smart... <tongue in cheek> | KingTor | Post - Surround - Video | 10 | 03-02-2010 09:47 AM |
Smart Tool / Pencil Tool in Midi Editor | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-26-2009 08:08 PM |
