Old 10-12-2022, 11:37 AM
itsjustmeee123 itsjustmeee123 is offline
Default Kontakt 7 and MIDI Control with mouse
With the newest version of Komplete 14 Ultimate there's lot of instruments that use an interface with visual box that allows up/down/left/right movement to control the levels and balance of the sounds. I'm wondering if there's a way to use the mouse as a midi controller to record the movement of it. Seems to me like a no brainer as opposed to setting a couple of midi controllers. Does anyone know if this is possible?
Old 10-12-2022, 12:33 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Default Re: Kontakt 7 and MIDI Control with mouse
If you're using a Mac, and have a trackpad, you can use AudioSwift. I do.
https://audioswiftapp.com
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 10-13-2022, 08:52 PM
audiolex1 audiolex1 is offline
MK. What OS are you running with your 5,1? Are you able to run NI 14 or Kontakt 7 in Mojave if you are running that OS?
Thanks
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 10-13-2022, 09:06 PM
So it works perfectly in Logic Pro. I just set the automation to "touch" and it records the X/Y movements of the mouse fine with Kontakt 7. Is this another thing that Logic has that Pro Tools is lagging behind in?
Old 10-13-2022, 10:08 PM
Thanks
Mostly I use it for the “Thrill” and Mysteria instruments in Kontakt 6 on my 5,1 with Mojave. I think I’ve also used it with u-He Zebra.
Kerry Smith
Old 10-14-2022, 08:12 AM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
I don’t believe Kontakt 7 will work on Mojave. At least not according to the NI Kontakt minimum specs.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
Old 10-14-2022, 12:43 PM
I figured it out. You have to go into the plug-in automation window, add X Mix and Y Intensity and then you're good to go. With Logic, you don't have to do that extra step.
Old 10-14-2022, 02:03 PM
Oh right. Yeah, I always have to add the parameters in the Automation window in the plugin. That's partly because of the way that Logic developed (MIDI sequencer - MIDI controls) compared to Pro Tools (audio - "Automation") years and years ago.
Kerry Smith
Old 10-14-2022, 04:50 PM
I know it says that, but it doesn't mean it won't work.Waves V14 doesn't say Mojave but it works.
Wonder if it is the same with NI 14.
Almost every plugin
Old 10-14-2022, 08:36 PM
I want to purchase the Ultimate Komplete update, but have read that it is not showing Kontakt 7 in the NI installer.
If anyone knows if it works with Mojave please speak up.
Thanks!
S3 No USB Mouse and Keybord Control? JC77 Avid S1, S3, Dock and Control App 2 04-19-2021 05:12 AM
D-Control Mouse Plate Beatstreet ICON & C|24 0 01-27-2016 11:55 AM
Control surface vs mouse??? stormmusic Artist Series 19 01-17-2011 08:36 PM
Control + New Mac Mouse ,,,cool bryanbassett Pro Tools TDM Systems (Mac) 0 04-20-2007 09:03 PM
Mix plus with control surface or HD2 with a mouse? WannabeSQ Post - Surround - Video 20 08-24-2005 01:51 PM
