Reason & Pro Tools Track Issue
Hi there,
Everything was working fine as of a day ago, I made NO changes to anything related, and now, when using Reason in Rewire mode in Pro Tools 8, there's an issue. I have 2 different Reason instruments setup to be used in a session. I set the MIDI Output selectors respectively. When I play one of these instruments, I get a level in not only its own main fader, but the other Reason instrument's (separate) PT fader as well. Also, I do get a level in the appropriate top MIDI fader in PT; however, it is the main bottom fader that is receiving both. In Reason, there is only active level for the one track and the correct "unchecked" boxes are unchecked, but somehow, Reason is sending that track's level to both PT tracks. I have already checked the Keyboard Setup in Reason - can someone help? Thanks, Matt |
Instrument Track MIDI playback Issue with Reason | djcrypto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-29-2013 07:11 PM |
Pro Tools 9 and Propellerhead Reason Loop issue | RuffinMedia | macOS | 0 | 08-13-2011 02:11 PM |
Pro Tools 8LE + reason 5 volume issue | sbowden42 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-23-2011 05:59 AM |
strange Reason/Pro Tools rewire tempo issue | scullionj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-26-2010 05:53 AM |
Latency issue with Pro Tools Rewire and Reason 3.0 | thenewnoise | Pro Tools TDM Systems (Mac) | 3 | 06-27-2005 06:31 PM |
