Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #31
Old 09-14-2021, 07:47 AM
its2loud its2loud is offline
Default Re: Can Any Real Experts in Routing Solve This?
Does anyone doing music setup their sessions with subgroups anymore?
Drums
Guitars
Bass
Keys
Pads
Lead Vox
BG Vox
If you setup your session with each subgroup via an Aux Track for each food group you can process each how you like. Then take the combined total of each subgroup to feed a MASTER MIX bus.
Create a Master track for the MASTER MIX bus for your mastering 2 mix.
Send each of your subgroups to the MASTER MIX bus
Then, for any other versions of the mix, such as VOX only, INST only, PERC only
Send each of those subgroups respectively to another bus called VOX ONLY MIX, INST ONLY MIX, etc. You can combine as you see fit.
Create a Master track for each of those respective busses and put whatever processing you like. Can be similar as 2 Mix but you're not going to get the same "Mastering" results on the respective stems because the audio will be affected differently when separate rather than as a whole.
The idea here is that the SUM of all the individual subgroups will equal the 2 Mix when added together.
If you want to MONITOR your 2 Mix, simply create a new Aux Track. Assign the input to this Aux track to MASTER MIX, send the output of this Aux Track to your Monitor Path. Now you can put any metering plugs on this aux if you want to meter your 2 Mix. Call the Aux track MONITOR
This as all been explained throughout this thread in various ways.
When you want to bounce, choose all the BUSSES you want to bounce such as MASTER MIX, VOX ONLY MIX, INST ONLY and you'll get your desired result.
  #32
Old 09-14-2021, 10:56 AM
tomhartman tomhartman is offline
Yes have this exact setup.
Found my mistake, the additional master faders were assigned improperly.
Thx
  #33
Old 09-26-2021, 12:31 PM
So today, I went to use this "multi bounce" setup and some weird thing is going on. Normally I copy whatever FX I have on the main Master, to the two alternative versions (background vocals and Instrumental versions). Today, even though I have done that, the alternative versions are not as loud and tests are showing they are not getting the same processing. I actually put a tremolo plug in on all three versions, bounced them, and only the main Master out had the tree on it, even though the plug in was on all three. So FX that have been copied over are not being recorded. What dumb thing could I be doing ? Her is a pic of the output section of the mixer....
https://www.dropbox.com/s/6trv3ehnbv...%20PM.png?dl=0
For Sale: MusicLab Real Guitar & Real Strat Becharax Buy & Sell 4 10-30-2015 11:53 PM
routing pc mic to pro tools and play back in real time latprod Windows 4 03-19-2014 05:57 AM
Real-Time Bounce to Disk...REAL PAIN Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 201 07-26-2010 08:12 AM
Routing question for experts andre tchmil Pro Tools TDM Systems (Mac) 11 10-24-2006 02:27 PM
To Digi and experts-Most efficient plugin routing method(s)? VibeTribe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-16-2001 09:17 AM
