  #21
Old 10-08-2021, 10:48 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Windows 11 comes out Oct 5th
Originally Posted by Benoni View Post
Apparently Microsoft has given a workaround for TPM1.2 and an unsupported CPU. You just have to change some registry settings. I'll probably give a shot later today. Will report back if it works.
It does work, but MS makes it sound like they will not push updates to unsupported systems running 11. I’m not sure what that exactly means, but just be aware.
Will
System Details
  #22
Old 10-08-2021, 12:16 PM
Benoni's Avatar
Benoni Benoni is offline
Yeah, its some real strange wording. I can't imagine MS would publish the workaround and then not push updates to those systems. But who knows.
My GUESS would be they are just covering all bases in case someones computer gets fubared, and I'm sure some will since the registry is not very user friendly.
Only do this if you don't mind totally messing up your system - potentially.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #23
Old 10-08-2021, 04:02 PM
Benoni's Avatar
Everything installed fine on a HP Z820 with TPM 1.2 and a non-supported CPU.
All apps are still installed and everything is working so far.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #24
Old 10-08-2021, 06:14 PM
EGS's Avatar
EGS EGS is offline
I just converted MBR to GPT, using Macrium Reflect Free. Worked. Next, in bios, I enabled Secure Boot. Worked. Windows Update now says:
"This PC can run Windows 11
Great news—your PC meets the minimum system requirements for Windows 11. Specific timing for when it will be offered can vary as we get it ready for you."
And the 11 update is NOT (yet) listed. They're rolling it out in stages. I'm gonna wait until they push it out to me (rather than using the Microsoft Windows 11 Installation Assistant tool). No rush.
Click for audio/video demo
Click for resume
  #25
Old 10-09-2021, 05:46 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I understand people running the very latest generation of Intel CPUs will see a performance update which makes it well worth upgrading. The rest of us, not so much.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #26
Old 10-09-2021, 11:44 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by Bob Olhsson View Post
... latest generation of Intel CPUs will see a performance update ...
Might be cool dunno: https://www.cnet.com/tech/computing/...er-lake-chips/
Click for resume
  #27
Old 10-13-2021, 03:26 PM
Benoni's Avatar
For the record, I did receive updates the other day. Hopefully that will continue.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #28
Old 10-13-2021, 03:35 PM
Benoni's Avatar
I used the official Microsoft method to upgrade my unsupported PC (HP Z820) to Windows 11. You can bypass the check for TPM2.0 and CPU, but you will need TPM 1.2 and the other requirements like enough hard drive space, ram, secure boot, etc...
If you want to try it yourself it's pretty easy, but there are always risks when you modify the registry. Proceed only if you accept those risks! Create a FULL backup ON ANOTHER DRIVE before you try this.
Here's a full video with the links you need in the description. Available on YouTube, Rumble, and Odysee.
The OFFICIAL way to Upgrade to WINDOWS 11 with an UNSUPPORTED Computer for FREE 🔥
https://youtu.be/s28TlbINbUE
https://rumble.com/vnpl9f-the-offici...uter-for-.html
https://odysee.com/@benonitech:d/Upg...supported-PC:5
Couple points:
Make sure you install ALL Windows 10 updates before doing this, otherwise you won't find the MoSetup folder in your registry.
Backup EVERYTHING before you begin (unless you really like to take risks)
Unplug your iLok before installing.
There is another way to do this where you don't need TPM at all, but it's not approved by MS. So, you'll have to find that yourself at Tom's Hardware.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #29
Old 10-13-2021, 04:05 PM
EGS's Avatar
EGS EGS is offline
I used the official Microsoft method to upgrade my unsupported PC (HP Z820) to Windows 11...
Cool! How does Pro Tools work on Win11? Plugs? Any issues? Thnx.
Click for resume
  #30
Old 10-13-2021, 04:32 PM
The Weed's Avatar
The Weed The Weed is offline
I looked at Tom's Hardware. Nice solution and, since I backup my OS drive nightly, worth a try.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Pro Tools tabbed windows in MacOs - Windows configuration not working hugocentrique macOS 3 11-06-2023 05:26 AM
Audio glitches with Fast Track Ultra on Windows 10 after updating Windows 10 GregS FireWire & USB Audio Interfaces (Win) 6 12-25-2015 03:40 PM
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-12-2010 01:46 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 10:02 AM
