Old 05-13-2013, 07:09 AM
Dstryr Dstryr is offline
Default Instrument Track: Stereo converted to Mono
I have an Instrument track with a Signal Generator and several other plugins on, from which I inadvertently deleted some automation data. The track is a mono Instrument track.
I checked on my previously Carbon Copy Cloned version and it's all correct, so tried Importing Session Data, but then I noticed that the track is stereo, which means I can't copy and paste my automation data to the new track.
How has this happened? And is there any way of converting the newly imported Session Data into Mono, so that I can copy over my automation data?
Thanks
Edit: Screenshot attached of the two tracks. Signal is the track I want to keep (as I have modified it in other ways since the backup) and paste the automation data onto, and Signal.1 is the result of Import Session Data. You can see one's mono the other's stereo: http://www.flickr.com/photos/6936867...in/photostream
Wie man mit dem Hammer Musik Macht
iMac 3.06 GHz Intel Core 2 Duo » 4GB RAM » Mbox 2 Pro » PT 10.3.4 » OS X 10.8.3 » Formac 500GB » Alesis M1 Active Mk2
Old 05-13-2013, 07:34 AM
Default Re: Instrument Track: Stereo converted to Mono
I've found the source of the problem, but I don't know how to get around it.
When I change Amplitube to No Insert, it removes all automation data from subsequent plugins in the chain. This is the only plugin which makes PT think it needs a stereo track (because it is listed as "mono/stereo").
I can Import Session Data to a new track, the created track is stereo, remove Amplitube (which converts it to a mono track), but then all automation data on subsequent plugins is gone.
A message pops up when trying to remove Amplitube which says "Removing the insert will cause ." Which is of course remarkably helpful.
Old 05-13-2013, 08:43 AM
The Weed's Avatar
The Weed The Weed is offline
Just make the Amplitude plug-in inactive?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-14-2013, 05:24 AM
Good shout, didn't work if I made it inactive on the new track I'd imported session data to, it remained as stereo and therefore I couldn't paste the automation data to it. But I reinserted an Amplitube on my destination track and then made it inactive, that worked.
Thanks!
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
Mono to Stereo Instrument track mike e.t. Pro Tools M-Powered (Mac) 1 05-04-2010 02:11 AM
Mono Instrument Track VS Stereo Instrument Track mbox2issue Tips & Tricks 8 04-20-2009 04:21 PM
Stereo track vs. Mono track vs. Stereo Interleaved track >>>>>>>>>>> peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 06-26-2002 03:21 PM
can you not copy automation data from a mono track to a stereo track? Felix Tips & Tricks 5 04-09-2002 06:32 PM
