Old 07-11-2010, 11:23 AM
adtnj adtnj is offline
Angry 8.0.4 crackling noise during playback 003 Factory
Just installed 8.0.4 on Vista 32, HP 2.4 Quad core, 4GB RAM, 1TB external drive hooked up to PC VIA SIIG firewire card with TI chipset. Prior to the 8.0.4 update I didn't get any noise playing back tracks. Now I do. Any suggestions?
Old 07-11-2010, 12:49 PM
Default Re: 8.0.4 crackling noise during playback 003 Factory
Do you have anything attached to the 003 via SPDIF or Optical? You might have lost the clock setting there. Otherwise, trash prefs and cross your fingers Mine works fine, but I am running XP.
Old 07-13-2010, 03:57 PM
jeid jeid is offline
Having the exact same problem. It's driving me nuts. Time to trash prefs and try again!
Old 07-13-2010, 04:05 PM
TOM@METRO's Avatar
I know there are people running 8.0.4 in XP and Vista but my experience still holds that on my builds, W7/64 is far smoother and feels quicker.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 07-13-2010, 04:14 PM
Sorry, should've stated, I'm running it on a Mac.
Old 07-13-2010, 05:19 PM
KrazieKraze KrazieKraze is offline
I had a noise problem at first when I was checking out a project file once I instlaled 8.04. About every 5 seconds I'd get a "psshh" sound. I figured out it was amplitude. Turned it off and the noise sound stopped. Not a perfect solution by far, but worth checking if the noise is coming from a particular channel
i7 920
6gb RAM
300gb Raptor
1TB Sata 2
Windows 7 Pro 64bit
Digi 003
Mbox (original)
Old 07-13-2010, 06:09 PM
Trashed my prefs and the crackling has stopped but I tried bouncing a track to disk and it started and then the sound dropped out and my 003 says it's offline. Now PT is just hanging. It's "Not Responding".
Old 07-14-2010, 07:13 AM
Default Re: 8.0.4 crackling noise during playback 003 Factory Sandra report attached
Now if I try bouncing to disk I lose connection to the 003.
SiSoftware Sandra
Computer
Model : HP-Pavilion GQ500AA-ABA m9080n
Workgroup : WORKGROUP
Host Name : HP
User : Alan
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Speed : 2.4GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Asus Berkeley
BIOS : AMI 5.13 10/24/2007
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.25GB DIMM DDR2 DDR3
Chipset
Model : HP P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 267MHz (1GHz)
Total Memory : 4GB DIMM DDR2 DDR3
Memory Bus Speed : 2x 401MHz (802MHz)
Memory Module(s)
Memory Module : OCZ OCZ2P8002G 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Video Adapter : NVIDIA GeForce 8800 GTS (96 SM4.0 1.1GHz, 640MB DDR3 2x792MHz, PCIe 1.00 x16)
Graphics Processor
Adapter : NVIDIA GeForce 8800 GTS (96SP 12C 1.19GHz, 615MB 2x792MHz)
Adapter : NVIDIA GeForce 8800 GTS (96SP 1.1GHz, 615MB 2x792MHz)
Storage Devices
Seagate ST3500630AS (500.1GB, SATA300, 3.5", NCQ, 16MB Cache) : 466GB (C:) (D:)
Seagate ST3500630AS (500.1GB, SATA300, 3.5", NCQ, 16MB Cache) : 466GB (E:)
WDC WD6400AAVS-00G9B1 (640.1GB, USB/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache) : 596GB (L:)
Hitachi HDT721010SLA360 (1TB, FireWire/1394/SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 932GB (M:)
Generic-Compact Flash (USB) : N/A (H:)
Generic-SM/xD-Picture (USB) : N/A (I:)
Generic-SD/MMC (USB) : N/A (J:)
Generic-MS/MS-Pro (USB) : N/A (K:)
ATAPI DVD A DH16A1L (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:)
ASUS DVD-E616A3T (ATAPI, DVD+-R, CD-R, 198kB Cache) : N/A (G:)
Disk : N/A (N:)
Logical Storage Devices
HP (C:) : 457GB (NTFS) @ Seagate ST3500630AS (500.1GB, SATA300, 3.5", NCQ, 16MB Cache)
FACTORY_IMAGE (D:) : 9GB (NTFS) @ Seagate ST3500630AS (500.1GB, SATA300, 3.5", NCQ, 16MB Cache)
HP HD2 (E:) : 466GB (NTFS) @ Seagate ST3500630AS (500.1GB, SATA300, 3.5", NCQ, 16MB Cache)
Optical Drive (F:) : N/A @ ATAPI DVD A DH16A1L (ATAPI, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (G:) : N/A @ ASUS DVD-E616A3T (ATAPI, DVD+-R, CD-R, 198kB Cache)
Optical Drive (N:) : N/A @ Disk
Elements (L:) : 596GB (FAT32) @ WDC WD6400AAVS-00G9B1 (640.1GB, USB/SATA300, 3.5", 5400rpm, NCQ, 8MB Cache)
LaCie (M:) : 932GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, FireWire/1394/SATA300, 3.5", 7200rpm, NCQ, 15MB Cache)
Removable Drive (H:) : N/A @ Generic-Compact Flash (USB)
Removable Drive (I:) : N/A @ Generic-SM/xD-Picture (USB)
Removable Drive (J:) : N/A @ Generic-SD/MMC (USB)
Removable Drive (K:) : N/A @ Generic-MS/MS-Pro (USB)
Peripherals
LPC Hub Controller 1 : HP (ICH9) LPC Interface Controller
LPC Legacy Controller 1 : Asus F8000
Audio Device : HP (ICH9) HD Audio Controller
Audio Codec : Realtek Semiconductor 888 High Definition Audio
Disk Controller : HP ICH8R (ICH8) SATA RAID Controller
USB Controller 1 : HP (ICH9) USB Universal Host Controller
USB Controller 2 : HP (ICH9) USB Universal Host Controller
USB Controller 3 : HP (ICH9) USB2 Enhanced Host Controller
USB Controller 4 : HP (ICH9) USB Universal Host Controller
USB Controller 5 : HP (ICH9) USB Universal Host Controller
USB Controller 6 : HP (ICH9) USB Universal Host Controller
USB Controller 7 : HP (ICH9) USB Universal Host Controller
USB Controller 8 : HP (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : HP FW322/323 IEEE1394 OHCI FireWire Controller
FireWire/1394 Controller 2 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link)
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote Driver (300x300, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Officejet Pro 8500 A909g Series fax (200x200, Colour)
Printer : HP Officejet Pro 8500 A909g Series (600x600, Colour)
Printer : Adobe PDF Converter (4000x4000, Colour)
Scanners and Cameras
Scanner : Hewlett-Packard 8500 A909g,192.168.1.6 (Scanner, 4800x4800, USB)
Peripherals
Media Player : ()
Media Player : ()
Media Player : ()
Media Player : ()
Network Services
Network Adapter : Intel(R) 82566DC-2 Gigabit Network Connection (Ethernet, 1Gbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows Vista Ultimate 6.00.6002 (Service Pack 2)
Platform Compliance : x86
Windows Experience Index
Current System : 5.5
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 07-18-2010, 08:56 AM
philip888's Avatar
philip888 philip888 is offline
Bump
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 07-19-2010, 10:12 AM
DigiTechSupt's Avatar
*sigh*
Have you tried the 'Run As Administrator' suggestion from the General Troubleshooting thread?
Avid Audio Tech Support
Support FAQ
Crackling noise in playback mysg4ever Pro Tools SE and Essential (Win) 2 07-08-2014 08:38 PM
Crackling Noise on Playback... of anything itspangler macOS 6 09-04-2012 06:43 PM
Strange Hiss/Crackling noise During Playback shisty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-02-2012 02:20 PM
Unwanted crackling noise only upon playback babakdm Pro Tools M-Powered (Win) 14 04-16-2010 05:56 AM
crackling noise????????mbox???????playback???????? klownprince7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-16-2004 02:18 AM
