Old 04-10-2010, 01:36 PM
DeyBwah DeyBwah is offline
Default NEED HELP - Is this effects loop broken or just the way it works?
"When I plug in my Pod Pro FX processor to the effects loop, I turn all levels on the amp head and the Pod Pro to 0. I should have no signal when my volume on my guitar is on. This is not the case, when I barely turn the volume on the guitar up, it is getting a very loud signal while all the levels on the Pod Pro and the amp head are turned down to 0. There should be no signal at all when I do this right? I have a Marshall head I play through and every thing works fine when I play through it , so i assure you it is not my guitar or the Pod Pro."
I sold a Warhead head to this guy and that's his latest correspondence.
I've never used an FX loop before so I don't know if it's a malfunction or the guy doesn't know what he's doing. In any case, can someone who knows how FX loops work chime in with their thoughts and expertise?
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts."
-Albert Einstein
Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub
Old 04-10-2010, 02:07 PM
Mork_ Mork_ is offline
Default Re: NEED HELP - Is this effects loop broken or just the way it works?
Sounds like it's a parallel effects loop. If so there must be a mix knob somewhere. Google it :)
Old 04-10-2010, 02:25 PM
I don't think there's a mix knob. In fact, I'm 95% sure..
-Albert Einstein
Old 04-10-2010, 02:29 PM
Which model Warhead is it?
Old 04-10-2010, 02:32 PM
Original Warhead.
-Albert Einstein
Old 04-10-2010, 11:51 PM
Anyone?
-Albert Einstein
Old 04-11-2010, 12:57 AM
Well looking on the Randall website, all the amp heads seem to have either just a series loop or a series/parallel. I can't find any info on your old head anywhere. Is it the (Warhead) Dimebag?
Maybe you sould try the Randall forum: http://www.randallamplifiers.com/Forum/Forum/Forum.html
Old 04-11-2010, 10:52 AM
Thanks again Mork,
Do you know what the difference is in behavior with the series loop or the series/parallel? It's the original Dimebag Warhead.
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_6616wt_1166
I went ahead and posted in those forums and will report any findings. Thanks again.
-Albert Einstein
Old 04-11-2010, 01:55 PM
I've never used a parallel effects loop (my Boogie mk V has a serial loop) but I believe a parallel one has a wet and dry mix, hence the mix knob. A serial generally has a volume control for level.
Old 04-11-2010, 02:32 PM
Yep, I think this head has a serial FX loop then, there is no mix volume knob.
I asked him EXACTLY how he's setting/plugging everything in and will report his response ASAP.
-Albert Einstein
iLok physically broken but works fine... audiofp Pro Tools 9 12 03-28-2011 06:28 PM
Midi Beat Clock while in loop mode, is completely broken. technician 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 07-15-2010 04:02 PM
Loop play broken? remute 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-07-2009 10:45 AM
Effects loop? benwhitton Post - Surround - Video 1 07-12-2007 02:45 PM
Effects Return Loop Bassart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-22-2004 07:17 PM
