Old 10-16-2021, 12:08 PM
Armando Armando is offline
Default Carbon and Eucon, S3 and AVB??
Hello! What’s the latest on compatibility with these technologies and Carbon/PT Ultimate?? Thanks!!
Armando
Old 10-17-2021, 07:51 AM
Default Re: Carbon and Eucon, S3 and AVB??
What's the question? Carbon/S3/AVB all work well with a compatible Apple computer. Eucon works well on both Apple and Windows computers. AVB doesn't work on any Windows computer yet(sadly). Eucon allows the S3 to act as a control surface on most any system(just not as an interface). What did I miss?
Old 10-17-2021, 08:00 AM
Thanks! I’m just in the process of going from HD(TDM) to HDX and would like to know all the avenues available.
Armando
Old 10-17-2021, 04:05 PM
Its good to investigate everything, but I'm still not sure what the question is. Maybe it would help if you describe your needs and your budget
Old 10-17-2021, 08:49 PM
FWIW I don't think there will be a way to combine the AVB part of the S3 with the Carbon in any meaningful way; first, only a single Carbon is supported with the Hybrid Engine, and the S3 uses an older AVB packet format.
https://lukehoward.com/
Old 10-18-2021, 08:55 AM
True. But S3 can still act as a Eucon control surface with Carbon as the interface.
Old 10-18-2021, 09:01 AM
What about adding an AVB switch like the MOTU product?
Armando
Old 10-18-2021, 11:14 AM
I would dig thru the Carbon manual for that. I suspect that AVB switches are not approved, but I could be wrong. I believe I have read that to use Carbon AND S3, Carbon would connect to the Ethernet port and S3 would connect to a thunderbolt port with the proper adapter.
Old 10-18-2021, 12:28 PM
My recollection is that there is no 'support' for either hubs (MOTU or otherwise) nor for use of the 2nd port (for any reason). However, I think if you dig back through this sub-forum you will find someone who has hooked another AVB device up to the second Carbon port - I think it was an S3.
Dominic
EDIT: Here it is.
Originally Posted by quicksticks4 View Post
I have my Carbon wired directly into my Mac Mini (late 2018, only one ethernet port) and my Artist Control going into the second ethernet port on Carbon. Artist Control is working great with this setup.
Makes me curious, can Carbon pass a hard-wired internet signal through to the computer via the second ethernet port as well?
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
