processor amount in pro tools
Hey guys,
I have a Intel Quad Core 6600 processor running Pro Tools 7.4. I use all 4 processors at 95% as my configuration, and so far my system has been running stable and I am very happy with it. With that said, I have been poking around the duc and I'm getting the notion that I shouldn't be running Pro Tools using all 4 processors. Is this true? |
Re: processor amount in pro tools
The old saying, "if it ain't broke, don't fix it" still holds true. You can try setting for 3 processors to see if it makes any difference. The only reason to change is if you are having troubles. The idea ia to leave 1 processor dedicated to system operation(so RTAS processing does not tax it at all).
You should only need to reduce the number of processors if you're using, or have installed, plug-ins that cannot run on fully RTAS dedicated processors. If everything is working, I'd keep the settings as they are.
I have allways had it on just three so is tech Support saying its better to run all four then?
It depends - if you have plug-ins installed or in use in the session that cannot run properly on a fully dedicated RTAS processor, you may need to reduce the number of processors in the Playback Engine so the plug-in has a processor it can run on.
How do I keep track of the total amount voices I'm using in Pro Tools 10? | paulisdead | Pro Tools 10 | 8 | 05-05-2013 10:09 AM |
Pro Tools Won't Open...Small Amount of Text | mdf31 | macOS | 2 | 03-10-2013 10:11 AM |
Pro Tools using more CPU as I increase the amount of processors. Please help. | wreckthisplace | macOS | 25 | 01-04-2013 03:50 PM |
Need a small amount of help with P-Tools 7 | RiffWraith | Windows | 3 | 12-06-2011 08:16 AM |
