Old 07-26-2004, 06:54 PM
macr0w macr0w is offline
Default Rookie mistake
Last night I had a bass player and guitar player over to do some songs. And before we got started I played some CD's on my system. Well I set my clock to 44.1 for the CD's and when we started recording I forgot to change it back. And I opened a session that was 24 bit and 48K. So now I've got a 48K session with 44.1K audio recorded on it. It was really some good tracks too, good performance by all three of us. How can I salvage these tracks. Are they just 44.1? and can I import them into a 44.1 session? Or am I screwed? And how should I bounce them? Thanks in advance.
Intel I7 920
Asus P6T
Digi 002R.
Command/8
PTLE 7.1 MPT
www.clearspotrecording.com
Old 07-26-2004, 07:27 PM
Ruben_B Ruben_B is offline
Default Re: Rookie mistake
Do you have soundforge?
-Ruben
Old 07-26-2004, 07:31 PM
You can either import them into a 44.1kHz session or change the header info using my Header Investigator (check out my web site to download it).
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-26-2004, 07:43 PM
Hi Rail, thanks again for your help earlier today.
I'll do a clean install tonight so hopefully all will be well shortly. I will definitely back everything up tho cause i just got asked to submit some of my harmonic samples for a UK mag.Lucky i found this out before formatting cause i would have most likely not done the backup
Cheers,
Ruben
Old 07-26-2004, 10:19 PM
Matt Whritenour Matt Whritenour is offline
Rail
if u use this just remember that when ur in the session keep ur clock on 44.1 but bounce the
file to 48k then use the header investigator to set them to 44.1k because i had this problem
once and kept bouncing to 44.1k instead of 44k
www.klarityrecordingstudios.com
Old 07-27-2004, 04:31 AM
Cheers,
Ruben
Hey man, get your own thread.
Oh, and no I don't have soundforge.
And thanks Rail for the info
Intel I7 920
Asus P6T
Digi 002R.
Command/8
PTLE 7.1 MPT
Old 07-27-2004, 05:31 AM
Joz Joz is offline
i had this problem once and kept bouncing to 44.1 k instead of 44.8 k
Woah!! I want 44.8k too!!!!!
Joz
"I never hit a women with her clothes on!"
Old 07-27-2004, 09:58 AM
Joz
hahah whoops...
Rookie Mistake: Installed Xpand1 over Xpand2 LT_CJ Virtual Instruments 3 03-20-2010 04:13 PM
Rookie Mistake guitar131 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-09-2007 07:13 AM
Rookie macr0w 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-02-2004 06:50 PM
Rookie Here The_Communist Tips & Tricks 4 02-28-2003 06:23 AM
Rookie Needs Help Derich Digidesign Hardware & Software 1 11-05-1998 09:07 AM
