Go Back   Avid Pro Audio Community > Pro Tools Hardware > MBOX Studio
Old 03-19-2023, 05:25 PM
Epiphanymusic Epiphanymusic is offline
Default All outputs in mono
I'm on windows OS and after downloading everything for Mbox studio, everything on my desktop as well as DAW only play in mono. My windows 11 is not set to mono and the physical button is not in mono, nor is the Mbox control software set on mono. I'm curious if this is a software problem? Or does the USB-C port have to be plugged into a 3.0 insert? I'm out of ideas of why this could be happening.
Old 03-20-2023, 07:41 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: All outputs in mono
The USB port should not matter in this case, so I would try doing a factory reset and seeing if it helps.
MBox Studio factory reset instructions:
1.) Open MBOX Control.
2.) Open the "Presets" Pane by clicking on the top menu bar button next to the Avid logo.
3.) Navigate to the "Factory" tab in the presets pane.
4.) Click on "FACTORY DEFAULT".
5.) Press "Load".
Will
System Details
Old 03-20-2023, 11:41 AM
Agree with junkgear, but wait! There's more. How your non-Pro Tools sounds are routed might be one issue because all the "channels" in Mbox Control are panned center by default(so finding the 2 channels for Windows audio and panning the 2 might help). For me, this is Internal 1 and 2 and they WERE panned center by default and I changed that(all non-Pro Tools audio now plays in proper stereo). As for DAW audio, what DAW? How experienced are you? Could it be a silly mistake of using a mono Master track?
Another question; are you listening over speakers or headphones? If headphones, open the utility menu(in Mbox Control, the little "gear" in the upper right-hand corner) and look at the Headphones section and note the 2 checkboxes to make either headphones mono(un-check the boxes).
Ozone outputs mono only, even on stereo track eric22rr The Drum Room 1 01-23-2011 07:36 AM
Adat Bridge 24 mono outputs billybroadsword Pro Tools TDM Systems (Mac) 2 12-09-2008 06:12 AM
M-BOX Micro only outputs MONO to headphones?! blacknight582 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-26-2008 09:02 PM
Digi 001 - Making Outputs MONO? atrest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-17-2003 08:14 PM
Mono out from 002 Rack's Main Outputs lenf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-08-2003 09:05 PM
