Old 02-26-2023, 07:22 AM
amathie amathie is offline
Default Burning small nudge of audio into the file.
I'm trying to streamline a workflow for time/phase aligning recorded live drums with multiple mics.
When I've worked out by how many samples I wish to move each track, I want to burn this into each source file so that the clip is still aligned with other clips in the edit window starting and finishing at the same time but that the audio within the clip has been slightly shifted. In this way, the clips are neatly arranged and when I send to collaborators I will know that they are hearing the tracks as I wanted without any risk of accidental change, for example if I had used the AVID Time Adjuster plugin or had entered a track specific delay compensation value.
I thought this would be simple by rendering the time shift using the AVID Time Adjuster via Audiosuite but the plugin doesn't have an Audiosuite version.
The clips represent the whole audio files and so they presumably don't have handles and would perhaps explain why I can't seem to use the nudge audio within clip using the "Slip mode holding down Control key" method.
What I'm trying to do sounds simple but I'm not experienced enough at editing to make this as simple as I hoped.
Any ideas from the experts?
Old 02-26-2023, 07:38 AM
its2loud its2loud is offline
Default Re: Burning small nudge of audio into the file.
Time align all your clips on the tracks as you want them.
Select all clips on the track highlighting from the start to finish that you want.
Consolidate clips SHIFT+OPT+3 (Mac)
Or it’s under the edit menu Consolidate Clips
This renders their alignment and create a new whole clip for the duration you selected.
Old 02-26-2023, 03:34 PM
Thanks so much... very helpful.
Old 02-26-2023, 06:29 PM
JFreak's Avatar
JFreak JFreak is online now
Yes, and for many other purposes consolidating comes in handy. But is that really necessary? Just use time adjuster plugin (and I would recommend Eventide's here) and be done with it. Consumes negligible CPU but takes one plugin slot.
Janne
Old 02-26-2023, 08:41 PM
The OP wants the alignment rendered to a specific length so all clips and tracks start and end at the same place.
“ I want to burn this into each source file so that the clip is still aligned with other clips in the edit window starting and finishing at the same time”
Therefore it’s either use Time Adjuster as a track plug-in then Commit the track to selection or edit so it’s aligned and consolidate. 6 of one, half a dozen of the other.
Old 02-27-2023, 01:45 AM
Yes, that sounds useful and must have a look at that.
For me, perhaps it's more a question of workflow and making a psychological break between technical and creative tasks. I want to prep all the tracks, doing initial gain trims, comping, removing unwanted sounds, timing and pitch corrections and have those burnt into a stable foundation so that all tracks start and finish at the same time and all plugin slots are effectively empty. I can share the tracks and sessions like that if required, knowing that it will open and sound as expected on any PT systems. That's the idea that seems to make sense to me, not that I have huge experience!
Old 02-27-2023, 07:16 AM
Then this workflow involves committing the tracks or creating stems or splits of your individual tracks.
Here’s some info on Commit
https://www.avid.com/avid/data/Video...=PromotestCode
Error 32 and 9073 trying to record small file. tomason Pro Tools M-Powered (Win) 4 05-03-2012 05:05 AM
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? EricHirsch ICON & C|24 1 08-13-2009 08:07 AM
any1 know how2 convert small region into wav file? audiodog1 Pro Tools M-Powered (Win) 7 07-29-2007 10:19 PM
Can't access nudge popup:screen too small? Billy Mayhem Digidesign Hardware & Software 1 06-15-2004 09:28 PM
Burning a mix into a Quicktime Movie File zoot666 Pro Tools TDM Systems (Mac) 1 09-20-2003 09:34 PM
