  #31
Old 02-19-2023, 12:25 PM
jonesaudio jonesaudio is offline
Default Re: Cursor filckering problem
That's a typo above ^
Operating system is Ventura 13.2.1
  #32
Old 02-19-2023, 12:37 PM
According to the update in Avid Link, it looks like ProTools 2022.12 provides support for Ventura.
File Type: jpg Screenshot 2023-02-19 at 3.33.06 PM.jpg (13.5 KB, 0 views)
  #33
Old 03-21-2023, 08:22 AM
silkpurse silkpurse is offline
Do we have a solution yet. I cant work with this flickering.
  #34
Old 03-21-2023, 11:25 AM
nednednerb's Avatar
nednednerb nednednerb is offline
In this thread I mention about FOUR or FIVE times a solution is RESIZE YOUR WINDOW. It is a temporary workaround. It works for me usually until I'm done my work for the time being.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
  #35
Old 04-08-2023, 07:55 AM
K Roche's Avatar
K Roche K Roche is offline
Me thinks some people do not read the thread so yes as you said .
It's a Bug in Ventura
And the temporary FIX IS
Simply grab a lower corner of the edit window and move it a tiny bit either larger or smaller . The cursor will stop flickering
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #36
Old 04-08-2023, 12:17 PM
Ben Jenssen's Avatar
The flickering cursor was fixed with 2023.3. It's been mentioned on the forum several times.
  #37
Old 04-08-2023, 12:33 PM
K Roche's Avatar
That's good to know,,, for those of us still on earlier versions of PT I guess resizing will have to suffice
System :
Enjoy the Journey
.... Kev...
  #38
Old 06-10-2023, 09:53 AM
Plec Plec is offline
The flickering might be gone, but it’s still irritating that the tool changes into a mouse pointer.
  #39
Old 07-04-2023, 02:19 AM
htk htk is offline
Do i need upgrade from 2022.12 to 2023.3 for solve this issue? 275$ crazy. Avid, Do you have a conscience?
  #40
Old 07-04-2023, 10:48 AM
nednednerb's Avatar
I believe it is a MacOS issue combined with PT's extensive use of many cursors.
The issue crept into greater visibility since sometime even before 2022.12, but it seemed, yes, to be quite visible in 2023.3, but now in 2023.6 on latest Ventura release, things are much improved.
Again, the issue existed prior to 2022.12, the issue was indeed MacOS related (I saw the issue on occasion in other apps with cursor changes), but I've seen it less in the latest versions
Note: Ventura, Silicon PT, Silicon MacOS, all these are relatively new and at the same time PT is trying to be compatible with a whole bunch of systems.
The consideration above is partly why some users on here hope for the latest release to fix the latest bugs and why some users on here take years to upgrade software, OS, as well as hardware.
There is something much more stable about a "final version of PT" that matches a "last OS version" and "stable hardware."
There are often sessions with a LOT of audio inputs recording, connecting to gear, and sessions can be much more expensive to run than the PT cost you mention. Therefore, stability is key and why many people on here simply don't expect a new version of PT on a new OS to always be rock solid.
It's not quite that combinations randomly fail. In this situation, it's quite easy to find out MacOS, and PT in this case may still be getting smoothed out.
Sent from my Pixel 6 Pro using Tapatalk
___
>> me: nednednerB //
CURSOR PROBLEM Tom LaRosa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-17-2007 01:54 PM
cursor problem studiolord 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-13-2007 10:56 PM
cursor problem... torstenhallin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-17-2004 10:53 AM
Cursor problem... Bodhisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-08-2004 02:07 PM
Having a problem with the cursor... GrahamCA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-09-2004 02:54 PM
