#521
Re: New "Mac Studio" from Apple
One obvious difference is Pro Tools and all plugins today are running in Rosetta 2, and that can be magical and just work, but like all translators there will be cases where it will do pathological things, hopefully they are rare cases... and many people's experience seems OK, but I sure would not take that Pro Tools and plugins running under Rosetta 2 will be OK for everybody because it was OK for somebody else. And likewise I would not assume it was bad for somebody because it was bad for something else. Because of Rosetta 2 I expect more variability here with Pro Tools having more dependence on workload and plugins causing problems than normal. There are just likely to be many opportunities for different things to behave badly, when going through a transition like this. But who knows what? It's going to take hard core developers looking at native ports of stuff over time, maybe there are interactions with efficiency and performance cores that you did not have on x86. Maybe something caused by uniform memory and GPUs. And maybe cases where the Apple silicon instruction set/compiler chain etc does need some tweaking. Who knows, but there will be stuff that needs work. There is always a long-tail with stuff like this. Lots happens quickly, then a long tail to get stuff all optimized, and along the way some things just won't happen or won't happen fast enough... e.g. we'll find plugins that don't' get ported to native or have too many problems and we'll have to give up on them. Plugin vendors who don't have competent in-house development teams (and maybe we can guess some of those?) uh maybe get ready to say goodbye to. Stuff will take time to optimize with a native port to Apple Silicon and for a time later. And that will take work from Avid, Pace/JUCE, and plugin developers. Folsk with heavy GPU workloads on the Ultra are seeing it may not scale as well as it can and needs optimization. Another example of just so much changing and optimization being needed. And it's maybe amusing to see reviews of the new Apple gear like where reviewers have to come back and point out the apparent very high GPU utilization they are seeing in tests does not mean the GPU is really working at 100% (always be a bit cautious about relying on what utilization meters tell you). E.g. see https://www.youtube.com/watch?v=HJQyLvLUoWg but be cautious Max Tech has a lot of clickbait. Last edited by Darryl Ramm; 04-15-2022 at 02:06 PM. |
#522
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
#523
#524
I suddenly feel a bit more optimistic. Come on Avid! |
#525
I tried to explain why that may be a bad idea. Be very careful just "wanting more". I was trying to answer if this is possible or not, most folks are saying it's not possible, and that's likely so close to being correct as I doubt Avid would do this... but I was just trying to be a bit more technically accurate since folks are going to start noticing what Apple did in Logic Pro.
Compared to Apple Avid is a struggling company with so much technical talent lost over the years, and part of it's developers--the outsourced team based Ukraine is unfortunately affected by !@#$% Russia's aggression. I hope Avid does not try to support Intel plugins on a native Pro Tools port. Any competent plugin developer will be doing native ports, for many of them that native code will be developed on JUCE and lots of stuff (esp. UI) shared across AAX, AU and VST. For some it may be just a recompile, but hopefully lots of QA and some optimization/tweaks. But folks who are competent, supporting products *will* be doing native ports... for multiple DAWs. I'd rather push on laggard developers to do their stuff, or let them be abandoned rather than have Avid jump through hoops, to make stuff more complex, maybe destabilize Pro Tools etc. doing unneeded complex stuff when they will have their hands full and could be spending that time getting the native DAW and plugins running as best as possible on native silicon. And that native plugin support on macOS will likely go away after a while when Apple ends of life Rosetta 2 support. And for somebody who absolutely absolutely needs an Intel plugin in the short term they will be able to run x86 Pro Tools and x86 plugins all within Rosetta 2. Last edited by Darryl Ramm; 04-15-2022 at 04:43 PM. |
#526
#527
With 100s of plugins, is there an easy way to check what is native and which are up to date?
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
#528
https://www.pro-tools-expert.com/app...tibility-guide |
#529
I ordered an M1 Max Macbook Pro back in early March. It's still showing as due in 3-10 days from now. I can only hope that happens, but I'll consider myself lucky if it does. This will be a transitional machine for me. I've long used a Macbook for location recording (classical), so this will replace that. I'll use Logic (because it's native) for recording and then throw it into PT in my desktop machine. But it will also give me a chance to test performance under Rosetta. I'll be able to test stuff like the Dolby Atmos renderer, VEPro and various other things in, um, retirement. That will at least give me some sense about what I'll really need when I fully make the jump to Native. My current laptop is a 2018 i9 and the thing sounds like a hovercraft. It takes very little provocation to spin up those fans. So I am quite curious about the relative acoustic level of the new one whenever it arrives. If I learn anything useful I'll post it here. |
#530
Wed, 16th March
Re-Recording Mixer/Sound Designer Sydney Australia ---------------------------------------- OS Monterey ProTools Ultimate 2022.4 Presonus Quantum 4848 Mac Studio M1 10 Core, 64gig RAM Sonnet Echo dual NVMe TB Dock Blackmagic Decklink 3G |
Complete Recording Studio FOR SALE! Pro Toold Hd2 Accel, C24, Apple, Mogami, etc... | sketchellis | Buy & Sell | 15 | 05-06-2013 06:27 PM |
apple-m "mute region" clash with finder apple-m "minimize" | wez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-12-2007 05:19 AM |
2 Power-Mac's on 1 Apple Studio Display? | Optimus Prime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2004 01:11 PM |
Has anyone had this problem with their Apple Studio Display? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-29-2002 12:55 AM |
Please advise on best setting on Apple Studio Display LCD Flatscreens - going blind! | Jules | Pro Tools TDM Systems (Mac) | 5 | 05-05-2001 12:54 AM |
