Pro Tools suddenly opens in older version
Hmm. I've been running v7.4 happily for years. Today, I opened Pro Tools and there was a problem with the 003 rack (which has happened before) where the interface restarts itself while Pro Tools is opening and then I get a message saying Pro Tools can't communicate with the interface. Normally, I quit Pro Tools and restart the interface again and everything is cool. Today, though, after going through this process all my sessions now open in v7.3.1. I tried saving a copy in the latest version, but got the same problem. I tried opening a new session--still v7.3.1. I tried opening a recent session backup file, but still, same problem. Any ideas?
(I'm running Pro Tools LE on Mac OS 10.4.11) |
Re: Pro Tools suddenly opens in older version
Check your default.
Go to your session folder -> select the ".ptf" session file -> Rt click & select "Get Info" -> the 4th drop-down tab should read "Open With" -> This will be your default application for opening a file. You can change it here as well... Good Luck Sparky |
The only option I see here is Pro Tools LE (default), which was already selected.
Weird behavior for sure.....
Are you able to reload 7.4? Sparky |
Structure opens empty when I load older session | andygray | Virtual Instruments | 1 | 02-04-2010 11:10 AM |
Pro tools conflict with older version on 2nd HD | julianlede | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-21-2009 02:09 PM |
Which version of Pro Tools LE 7 is best for my older Mac G4 | MIC FIEND | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-23-2008 10:43 AM |
"older version of Pro Tools" error | HearInc | Pro Tools TDM Systems (Mac) | 7 | 08-18-2008 11:11 AM |
Older version of Pro tools | harpdog123 | General Discussion | 7 | 07-25-2001 09:58 AM |
