Old 10-10-2001, 10:31 PM
redarrow32 redarrow32 is offline
Default unable to open after 5.1.1 update
Someone please help!!! I just downloaded the 5.1.1 update and installed it. When I boot up pro tools it asks for the serial number and I put in the one that came with the system(inside cover of getting started manual). It say that it is an invalid serial number. I have made shure that I put it in exactly as it is typed, ie caps sensitive. Fortuanatly for me I am at work while tech support is available. Can anyone help? Is there an email address for tech support that works? After spending a lot of money on the digi 001 it is very frustrating to have it unavailable!!!! Thanks
Old 10-10-2001, 10:51 PM
stevalex stevalex is offline
Default Re: unable to open after 5.1.1 update
Try to put the spaces where indicated as well look for the 0 or O (ceros) or the letter O,, on my serial number there is just ceros,
try it
good luck
Old 10-11-2001, 06:50 AM
Thanks, I tried again, but still no luck. All of the spaces are correct and I tried different combos of Os and zeros.
Old 10-11-2001, 08:27 AM
Avid's Avatar
Avid Avid is offline
Administrator
Make sure that the serial number is from the inside front cover of your Getting Started with Digi 001 or ToolBox XP booklet. The version of Pro Tools LE on the title page of the booklet must say 5.1, not 5.0.1.
If you purchased an upgrade to Pro Tools LE 5.1 online, then your 5.1 serial number is included in your confirmation/receipt.
When entering your serial number, all letters are case sensitive, and all "0" characters are zeros.
You can call or email tech support or customer service using the information on the contact page: http://www.digidesign.com/aboutus/contact
If you email, include your serial number so that we can check it for accuracy with your registration. It isn't likely, but it is possible that there is a misprint on your manual. I've seen that happen a couple of times.
A phone call would be the quickest way to resolve the problem, but you can also email. There may have been some glitches with the Technical Support Request form over the weekend while we moved many of our servers from our previous headquarters to our new location, but everything should be working now.
Bruce
Administrator
Still unable to open with PT 11.1 jeanfdem Windows 1 01-22-2014 05:47 AM
Unable to open Sessions (Tracks unable to load) palmify91 Pro Tools 10 1 03-27-2013 08:00 AM
PT 9.0.5 with Lion - unable to open other MIDI apps open as standalone Rebel macOS 29 05-22-2012 10:49 AM
Help - unable to open session G4/500 HD PT5.3 letrev Pro Tools TDM Systems (Mac) 4 05-15-2002 12:52 AM
Unable to Open Brimmy Pro Tools TDM Systems (Mac) 1 06-20-2001 05:40 AM
