Re: Pro Tools Audio folders
Here's a way to "untangle" them:
Make a seperate folder for each session. Open each session and do a "save session copy in...". Make sure you check the boxes for the audio-file to be copied too. After you checked each newly created session, you can trash the old bunch. Again: test first, trash the files, test again, empty trash...!
What's that? - That's the machine that goes "pling". Bastiaan |
"Use save session copy in and then trash the original".......
What a strange advice to give (specially to a newbie)...anyway... Follow Bassmac's advice and let PT do its job. As long as you name your session and your session's tracks properly(->the track's names will determine your audio files names), you'll be OK. Welcome to PT.
Some music?... http://tmweb.free.fr |
I hope no-one takes offence to this really simple question, but I'm a ProTools newbie..
I have several different PT sessions on my hardisk, they have different track title / folder names etc. And inside there are the Audio folders with their respective audio files inside . Is it normal to have several folders called "audio-files" ? Would this confuse the file heirarchy on my Mac? Or should I rename these folders to different names? thanks for the help voltech of the |
Renaming files or folders in the Mac finder will make ProTools unable to automatically locate them at start-up. As long you have a separate folder for each session that includes all your audio files, fades, etc. inside of it, you're in good shape.
It is a bad sytem that works well.
Thank's guys!!
that sorted me out [img]images/icons/wink.gif[/img] voltech |
missing audio 'folders'! HELP | rjk666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-29-2010 07:04 AM |
audio file folders | camsax | Storage Subsystems | 1 | 07-02-2007 05:21 PM |
audio file folders | camsax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-30-2007 12:40 PM |
Templates & Audio Folders | Dennis Scott | Pro Tools TDM Systems (Mac) | 4 | 11-19-2005 07:58 AM |
two hd an two audio files folders??? | luis mendez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-03-2004 10:32 AM |
