Re: carbon hardware setting in PT
thx , i will look into this , cant at the moment but will asap
you were right , it was unattenuated, main was selected, i appreciate everyones time, im glad i brought it to you guys, hopefully i can be a help in the future,
cheers |
If Main is selected, then MON L-R outputs would be attenuated. To clarify, is that the case and you're still getting very loud noise when using the "Test" button in AMS? Or, is that test noise now being emitted at a normal volume?
And, does monitoring control seem to be working ok in Pro Tools as well as other applications? Thanks.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
The problem, user , occurs when i had protools "aggregate" selected instead of "reserved for protools selected in audio midi setup, entirely my fault
Hope that helps.
#16
yes it does ,
i am taking the PT certification course, is there a source for instructions on how to use the available plugins, i am a musician first at this point, i want to be able to at least record and use plugins, i have tracks set up to record , no prob , i know all this will be covered later ,I am 1/4 through the first course, thank you |
#17
Additionally, there are a number of helpful videos here. For recording and using DSP plugins, I'd focus on these: Introducing Hybrid Engine Recording Basics Advanced Workflows
Setting up Hardware Inserts | amathie | Pro Tools 12 | 19 | 11-10-2016 11:36 AM |
Setting up Different Hardware Profiles | Allen Hallada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-22-2003 01:12 PM |
hardware buffer setting in cubase sx | Da Gatekeepa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-30-2002 08:13 PM |
hardware setting error | doyle204 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2002 02:59 PM |
