Old 05-27-2009, 01:18 AM
Greg B Greg B is offline
Default Quicktime Stutter
Like many of you, I assume that you're living with this problem as well. The audio stutter from Quicktime movie playback can be horrendous. I search on it every few months, and discover it's in every community and every platform.
I read a post where a fellow listened to his MOBO's audio out and QT didn't stutter. Ridiculous, I thought. Stuck my headphones into the MOBO jack and there was smooth playback. Incredible.
Ran a cable to my alt-source inputs and hit the alt src to mon button. Now if I have to deal with MOV files, at least I can hear the finished product w/o rage or play it for someone w/o incredible embarrasment.
Is this a clue for any genuises to help solve the problem?
Thanks,
Greg
002R Win7, no PT
GigaByte 970A-UD3/AMD FX(tm)-8120
8GB DIMM DDR3
AMD Radeon HD 6570
2 WDC WD10EURX-63FH1Y0
www.soundchasm.com
Old 05-27-2009, 09:44 AM
sw rec sw rec is offline
Default Re: Quicktime Stutter
Actually, exactly what you did! Welcome to the ranks of geniuses!!!!!
There's a "known issue" between PT and Quicktime/I-tunes, has been for YEARS.
But no "known solution!"
So your solution is the preferred one.
Old 05-27-2009, 11:58 AM
Well thanks for the invite!! In my searching, I actually ran across a post I made in 2005 when I thought I had been laden with the final straw. Hah!
I have no doubt whatsoever that the problem is insoluble. Still, I am thrilled to have a workaround.
002R Win7, no PT
8GB DIMM DDR3
AMD Radeon HD 6570
www.soundchasm.com
"Quicktime Priority" options missing and h264 playback stutter Sawdust 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-03-2010 12:55 PM
QT Stutter jjsoundoc Post - Surround - Video 1 10-31-2009 09:28 PM
Stutter When Using USB HUB edfermi MIDI 0 08-28-2009 09:28 AM
Stutter effect t0rn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-09-2009 08:36 PM
Quicktime stutter at 24fps in protools krank Pro Tools TDM Systems (Mac) 2 09-28-2000 04:32 PM
