Old 06-05-2020, 08:11 AM
musicmixer04 musicmixer04 is offline
Default Preferences TC/E setting change sound when using elastic audio?
Hi.
I use elastic audio for changing tempo of a track.
All tracks are set to ticks and to polyphonic.
The TC/E setting in Preferences is set to Avid Time Shift.
Lets say, If I change that to Avid TC/E or Waves sound shifter (which are my other options) Will it have any effect on the audio stretching done by elastic audio. Or is this plug in setting for something else?
Thanks
Old 06-05-2020, 09:22 AM
Default Re: Preferences TC/E setting change sound when using elastic audio?
I don't believe that setting affects anything when you change tempo. I also think using Polyphonic for everything is not a good idea. Things that are single note(like a voice or a bass) should use the Monophonic option and drums/percussion should use the Rhythmic option. Depending on how drastic you change the tempo, you may also find you need to replace some tracks(re-record at the desired tempo) as some things will not be conducive to big changes. Just my opinion
Old 06-06-2020, 06:21 AM
@albee1952 Thanks. thats cool info. I will be looking into using different plugins. Yeah my use will be for composition purposes (and some of it will be midi) and everything will be re-recorded for sure. What about transposing, maybe the settings will have effect there?
Old 06-06-2020, 07:50 AM
Originally Posted by musicmixer04 View Post
...The TC/E setting in Preferences is set to Avid Time Shift.
The TC/E pref determines what plug-in will be used when the trim tool is in TC/E mode - nothing to do with EA
http://www.richbreen.com
Old 06-06-2020, 08:12 AM
Transposing midi is super simple. Transposing audio is a bit different. To use Elastic Pitch, you enable the Polyphonic EA option and that allows you to transpose audio up or down. The thing with that is; transposing audio by a few steps(say from E to G) will often work well enough to keep. But going farther than 3 half-steps can start to sound weird(so some parts may just need to be re-played in the new key).
Old 06-06-2020, 01:13 PM
Cool info. Thanks! So these settings will not change the sound of Elastic Audio when I use it to transpose:)
Old 06-06-2020, 01:16 PM
Cool:)Great thanks for the tip! Thanks for helping, appreciate it!
Can't change tempo in elastic audio Thenewexhibit Pro Tools 12 1 03-17-2016 03:06 PM
Elastic Audio - How to increase tempo and not change pitch? Mike Borok Windows 2 02-04-2015 09:24 AM
Fragmentation of audio by Elastic Audio HD9 tempo change?? bassybob macOS 0 01-05-2012 03:11 PM
Elastic Audio Rhythmic to Polyphonic Setting Issues Monkey Puzzle Pro Tools TDM Systems (Mac) 6 04-29-2010 03:21 PM
how to Change tempo to an Elastic Audio'd track teacherman Tips & Tricks 7 04-15-2009 06:49 AM
