Old 02-27-2015, 10:36 AM
Joejoe1414 Joejoe1414 is offline
Default Unable to import video
Hello, I've been using Pro Tools for about 4 years now. I have a 2.53 Ghz mid 2009 MB Pro with 2 gigs of RAM. I know this issue has been discussed before but I have not found a solution.
When I first import my .Mov file into PT I got an error message saying "unable to link file due to missing codec". That message no longer appears but my video is just a black screen with the extracted audio. This is very frustrating. If anyone know a fix for this that would be great. I do not use Avid Media Composer if that makes a difference...
Thanks
Joe
Old 02-27-2015, 01:31 PM
Craig F Craig F is offline
Default Re: Unable to import video
.Mov is just a container type and is meaningless, open in QuickTime Player and use Inspector to get the real information on Codec
Thank you,
Craig
Old 02-27-2015, 01:43 PM
lancemcv's Avatar
lancemcv lancemcv is offline
Try exporting the video to Pro Res 422 in quicktime if you have quicktime 7 pro that is. Then you should be able to import.
Old 02-27-2015, 07:14 PM
cananball cananball is offline
If it's not a codec that Quicktime can natively read it won't open. If it's an DNxHD codec you need to download it from Avid. I've had trouble like this before when clients delivered XDCAM stuff to me.
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
Old 02-28-2015, 02:38 AM
onosendai onosendai is offline
I don't know which version of PT's you are using, but in some of the earlier builds of PT11 there was an issue with certain pro res files, where they would display as blank frames. Even my own transcodings from Compressor. At the time my workaround was using PT10, which had no issues or if i had the time transcode to DNxHD 36, which would work.
This might also be irrelevant to the issue, but if nothing else works, try relinking the video file from workspace. I have had the "... missing codec" pop up at times if I've moved the video file to another location between sessions.
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802
Old 02-28-2015, 12:21 PM
I tried importing from the workspace and no luck. I don't have Quicktime 7 but the video itself is a H.264 I re-installed PT10 to try importing it in there but I have the latest version of OS X and I do not want to go through the task of reverting back to Mavericks and risk losing all my data.
Is this a question of RAM? I feel like I should be able to import a video file no problem...
Old 02-28-2015, 12:36 PM
convert that POS h.264 to something usable http://www.squared5.com/
photo-JPEG or DNxHD36 would be my choices
Thank you,
Craig
Old 02-28-2015, 02:58 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Your MBP is a Core 2 Duo (like on of mine). Won't work with video, audio seems to be fine.
Video really needs i7 for lappys.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 02-28-2015, 03:13 PM
2 GB of RAM is on the very short side as well
4 GB minimum
8 GB for functionality
Thank you,
Craig
Old 03-02-2015, 12:37 PM
Thanks for the help everyone. ...So your saying even if I upgrade to 4 or 8 gigs of ram, I still won't be able to use video in PT ?
HTML code is On
Unable To Import .rx2 Files ProTooler Pro Tools TDM Systems (Mac) 5 03-24-2013 04:43 AM
Unable to import PCM files.... tonejunkee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-10-2009 12:28 PM
Unable to import .wav files Mike Borok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-06-2007 01:16 PM
L.E. 6.9 unable to import cd tracks ronoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-26-2007 05:41 PM
unable to import mp3 edwardo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-10-2004 09:08 AM
