Old 06-06-2022, 11:53 AM
fsrenduro fsrenduro is offline
Default Pre/Post Roll shortcut
I know there's a shortcut to turn Pre/Post roll on and off with Command-K but there's also a shortcut if you Option-Click in the timeline that activates the Pre Roll from that point (also turns on Pre Roll). Since I seem to accidentally hit this key combination frequently I'm looking for a way to turn that off all the time. In my 2 decades on Pro Tools I've never needed to do that and have done in by accident 1000's of times.
I thought about creating a shortcut in the Mac system that would conflict with that so maybe it wouldn't work but I can't use Option-Click as the 'keystroke'
Thanks
Mac Pro Quad Core 3.7
32 gigs RAM
Native Thunderbolt & Omni
OS 10.9.2
PT 10.3.10 HD
PT 11.3.1 HD
PT 12.1 HD
Old 06-06-2022, 05:48 PM
smurfyou smurfyou is online now
Default Re: Pre/Post Roll shortcut
Yes that drives me crazy every day. If you find a way to disable please share.
~Will
Old 06-07-2022, 05:43 AM
traksion traksion is offline
The only fix I've found is with using memory locations. I have a default starting template I use for every session using memory slots 1 through 9, I use these to change track views and/or window config views (with Time Properties set to none). And I also add Pre/Post Roll times in the options. I switch between the views frequently while working, so even if I accidentally change my pre/post roll, it always gets fixed when I change to a new view/memory location.
Old 06-12-2022, 07:32 PM
nednednerb's Avatar
nednednerb nednednerb is offline
At least now I know why that happens to me too. I option-scroll very often to zoom in and out, but like you I do not have a need for the option-click function to turn on and set the pre-roll.
How many times has AVID been asked to allow their keyboard shortcuts to be configurable or individually disabled, at least? This would not be the ONLY shortcut I might (even temporarily) disable, depending on workflow.
The ability to tell PT "no right now please don't listen for THAT specific combo" would make a smooth operation for such use contexts. Any other method, such as creating a system shortcut in an app like Keyboard Maestro, is a hacky method. Option-click does other things if you target a plugin or solo button, which might totally be desirable, when opt-clicking the timeline is what is problematic.
Old 06-20-2022, 09:30 PM
kevaudio kevaudio is offline
I believe you can write scripts via Soundflow to disable key commands built in to protools.
Pre-roll/post-roll appears to be broken in PT10 anodecathode macOS 1 02-20-2012 01:33 PM
Pre-roll doesn't work but post-roll does :confused: pennard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-06-2009 11:26 PM
pre/post roll shortcut adjustment fman Pro Tools TDM Systems (Mac) 2 11-05-2007 06:59 PM
Shortcut for Pre/Post Roll ? jbr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-09-2006 06:14 AM
keyboard shortcut to toggle pre/post roll rlcowa@work2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-13-2001 02:53 PM
