Old 05-16-2022, 07:24 AM
Default Shortcut Ket Commands ?
Hi All.
I've searched but found no info.
Is there a quick way to check if a short cut key command combination is used in Pro Tools ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 05-16-2022, 07:43 AM
smurfyou smurfyou is online now
Default Re: Shortcut Ket Commands ?
In the new 2022 version you can search in the Keyboard Shortcut assign window.
~Will
Old 05-16-2022, 07:51 AM
Yes, that's right Will. Thanks. .
In any previous versions though, it seems one has to search in the shortcuts document with quotation marks at either end, eg;
"Control+Option+Up Arrow"
Straight on . . .
Shortcut commands not working E-Lister Windows 4 02-24-2012 11:09 AM
Shortcut/Key commands gone Wisur Pro Tools TDM Systems (Win) 0 12-25-2006 09:19 AM
Shortcut commands LUEDEMANN Tips & Tricks 4 12-01-2004 12:36 AM
how do you activate the shortcut commands surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-25-2004 09:45 AM
Shortcut commands PlainJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-10-2004 03:44 PM
