Old 08-24-2021, 09:44 PM
Cale Cale is offline
Default Pro Tools 12.2 and Lexicon IO42, can only choose 256 samples as HW buffer
Hello,
I have seen various ways to fix this 256 samples buffer issue, including disabling the audio device in Windows Sounds, as well as ensuring the drivers are up to date. I have tried these things with no success.
If anyone has any suggestions, I'd very much appreciate the help.
Regards, Cale
Acer Predator PH315-51
Intel Core i7-8750H CPU @ 2.20Ghz
16GB RAM
Windows 10 Home
Lexicon IO|42
Pro Tools 12.2.0
Old 08-25-2021, 07:43 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro Tools 12.2 and Lexicon IO42, can only choose 256 samples as HW buffer
Does that interface have a buffer size available below 256 in it's software?
My RME UFX goes down to 48, but Pro Tools cannot use that, so the lowest I can go is 64, but I can change the buffer size in the UFX's software.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-25-2021, 07:55 PM
I could select other options including lower settings in Pro Tools 10.
I contacted Lexicon and they said they've ended support for this product due to ongoing compatibility issues with Windows 10. That suggests I will probably need a new interface. I'd rather keep using this if possible, so any suggestions are appreciated.
Old 08-25-2021, 08:28 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by Cale View Post
...I contacted Lexicon ... ongoing compatibility issues with Windows 10...
Well, if that's what the manufacturer is telling you, then I'd cut my losses and get a new working interface. Hey, it looks like Lexicon has drivers for Win32 bit and for 64 bit. Make sure to use 64 for ProTools 12.https://lexiconpro.com/en/softwares/...windows-64-bit
Click for audio/video demo
Click for resume
Old 08-25-2021, 09:58 PM
Thanks for the suggestion, I am using the correct drivers. They require driver signing to be turned off in the computer BIOS every time the computer starts up or the interface won't work. A bit ridiculous.
Old 08-26-2021, 06:58 AM
EGS's Avatar
EGS EGS is offline
...A bit ridiculous.
Move on to another interface.
Click for resume
Old 08-26-2021, 09:14 AM
EGS's Avatar
EGS EGS is offline
Looks like Lexicon doesn't offer ANY audio interfaces any longer https://lexiconpro.com/en/product_families
Click for resume
Old 08-26-2021, 11:42 AM
64 buffer is the lowest any USB interface will do reliably, no matter what the interface manufacturer says. Any time that you get a message that Pro Tools cannot change or control the buffer size, its most likely is that the OS or some other program is using the interface
help using 48 samples (buffer size) yl956 Pro Tools 12 4 06-15-2018 08:28 AM
96kHz/32bit Pro Tools HD 10/11 no option for 64 samples buffer CurveZer0 Pro Tools HDX & HD Native Systems (Mac) 6 01-09-2014 01:28 PM
I can't choose hardware buffer size!? hjllphilp Windows 1 03-16-2011 01:54 PM
What's the max H/W Buffer Samples Available in 6.9 Greg M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-02-2005 04:20 PM
don't get the buffer below 512 samples DeltaBeats 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-21-2005 10:18 AM
