Hardware insert still playing unprocessed signal
HELP!
I've just decided to try out some external hardware, and plumped for the FMR Audio RNLA. I'm using PT 12 and a Roland Studio Capture, and have followed all the guidance I can find as follows: - Out of channel 7-8 into L&R, out of compressor L&R back into 7-8 on interface - Assign Insert 7-8 on track in software I'm getting the processed signal, but if I mute the track I still have a version of the signal, over which I have no control at all. Further to this, when I'm routing a mono signal, this unprocessed rogue signal only comes out of the left channel. These problems are probably linked, and probably simple, but I've spent two days reading around this online to no avail! HELP! (again) |
Re: Hardware insert still playing unprocessed signal
I'm not familiar with the Roland unit, but does it have direct input monitoring, or it's own monitoring software? Is it possible that what you're hearing is from the direct monitoring and not from Pro Tools?
Pro Tools 2018.12 OS X 10.14.6 Mac Mini (2012) Quad 2.3 GHz Intel Core i7 16 GB 1600 MHz DDR3 RAM |
Yes it does!
I'd turned the Direct Monitor down, but not the DAW Monitor mix in the unit's software... Thanks! |
Pro Tools 11 only recording unprocessed dry signal. Eleven Rack. | DNET | Pro Tools 11 | 6 | 09-25-2016 05:37 PM |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
How to insert hardware as channel insert | Lqoau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-19-2012 07:29 AM |
changing insert plugin while loop playing | nigel smith | Pro Tools TDM Systems (Mac) | 8 | 05-24-2011 11:56 AM |
INSERT WHILE PLAYING ? | tid | General Discussion | 4 | 03-29-2000 02:42 PM |
