Old 08-12-2022, 02:18 PM
strej941 strej941 is offline
Default Studio Error, then cannot access Menu Bar / Shortcuts
So, I've been running into a problem frequently, and its interrupting my workflow and also killing my sessions with clients and I'm not sure what to do.
During my projects, I'll occasionally get a small glitch and then *everything* will stop working properly. This gif (https://gyazo.com/35cfbc64b3909b254e6b838b9a3180be) shows I'm missing/grayed out of the "View, Track, Clip, Event and Options" menus. This is not all though, I will lose all keyboard shortcuts that use CTRL or SHIFT.... I'm at a loss, as I can't even ctrl+s to save, I can't close the session, I can't cut/paste or do literally anything.
Steps I've taken - Reset ProTools Cache and Settings
Restarting PT:S works, but only for a few minutes.
Updated PC drivers and graphics drivers.
Any help would be *greatly* appreciated.
Old 08-12-2022, 03:02 PM
Default Re: Studio Error, then cannot access Menu Bar / Shortcuts
First thing to do is look near the top of this(and every) DUC page for the link named Help Us Help You and have a good read. Its nearly impossible to offer any help with almost zero info on the system("PC" and "PT-Studio" constitutes maybe 1% of the required info). Post a Sandra Lite report and include details on the interface and exact build versions of PT and OS.
Steps worth trying:
1-trash prefs(guitardom's Trasher utility available at pro-tools-pc.com is the best option for Windows machines).
2-If your system drive is a fast SSD, try running your session on that drive(a separate recording drive is ideal, but with the advent of fast SSD drives, its not the "requirement" that it once was).
3-you mention a "small glitch". So what might be causing this glitch? Turn off all networking and see if that helps. Open Task Manager and see what programs are running in the background. Have you performed ALL the required system tweaks?
4 and up will be a mystery until you provide complete system details
Alt-menu keyboard shortcuts - Alt+F for file menu, etc. scullionj Windows 7 11-22-2015 08:59 AM
laptop shortcuts for window menu (fn key not working?) NashGtr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-21-2010 08:54 PM
Can't Access Documents From Help Menu Blank Frank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-15-2007 10:41 PM
Creating shortcuts for menu objects JonesH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-07-2006 06:35 AM
Keyboard shortcuts - duplicate menu item names jeremyroberts Pro Tools TDM Systems (Mac) 0 11-18-2005 02:04 PM
