Old 05-22-2009, 12:58 PM
j77swift58's Avatar
j77swift58 j77swift58 is offline
Default new (intel) mac mini with PT LE 7.4
I'm very happy with OS 10.4.11, PT LE 7.4.2, and the mBox2 pro.
Sadly, my first generation Dual G5 2.0 (not dual core) is dying.
I see the PT 8 has been approved for the new mac minis (intel).
Does this mean that 7.4.2 will run on the new mac minis as well?
If yes and I buy the mini (with the 2.26 processor and 4GB RAM)
it will come with 10.5. Will this be problematic?
....thanks, I'm just trying to identify all the land mines in advance
Old 05-22-2009, 02:24 PM
jhamrick jhamrick is offline
Default Re: new (intel) mac mini with PT LE 7.4
7.4.2 is compatible -
Pro Tools 7.4.2 software requires Mac OS X 10.5.3 or 10.5.4, and is not compatible with earlier versions of Leopard.
The only issue I see is if you wanted to upgrade your ext Hard drive.
FireWire 800 drives are not supported for record and playback with Mbox 2 Pro systems
Since the New Mac mini only has FW800 you will want to get a cable that converts FW800 to FW400.
-Jesse
___________________________________________
Old 05-22-2009, 03:43 PM
anthonylv64 anthonylv64 is offline
Smile Re: new (intel) mac mini with PT LE 7.4
I'm running PTLE8 with a new mac mini, the 2.0 Ghz version, which is the cheapest, and 4 Mb of RAM upgrade, I haven't had a single glitch, so far, I ran 7.4 for a while before I upgraded, and no problems either, I just did the optimization recommended for Leopard, which is simple and everybody does anyways...and did I mentioned? I'm new to Mac, but everything is a lot easier, and smoother so far
Mac Mini or I3 Intel PC For LE 8 in the UK devineandrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-22-2010 12:55 AM
Mac Mini or I3 Intel PC For LE 8 in the UK devineandrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2010 02:57 AM
Any Mbox2 Mini/MAC Mini Intel Users? Need help with Reason Mbox2digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2007 07:37 AM
Anybody using PT 7.x on a Intel Mac Mini 1.83 gHz? ericfergus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2007 08:55 AM
Intel mac mini and m-powered arh Pro Tools M-Powered (Mac) 0 07-25-2006 01:37 PM
