Window Size.....still no solution
thot I'd post this again in case someone has come up with a solution. Running PT 9 on Windows 7, 64 bit.... Pro tools (or Windows) will not remember my window size. (I'm running dual monitors) Once I close PT, the next time I open it, it generally opens in a tiny window (approx 3" x 2") up in the left hand corner of my primary monitor. I then have to manually drag the window out again. Not the end of the world.... just an aggrevation
gofortheheart Pro Tools 9 Pentium Quad Core Windows 7 64 bit 8 GB DDR2 Ram 600 GB System Drive, 320 GB Recording Drive Tascam FW-1884, ART Tube Opto 8 |
Re: Window Size.....still no solution
Have you installed new graphics hardware or changed your screen resolution since PT was installed.
There were several reports of PT having problems adjusting to these new circumstances...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Once you drag the edges out and have all showing the way youy want, close by using the Alt-F4 command and see if that helps.
H/W Buffer Size issues (-6093), have tried many settings, no solution! | codydboyce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-06-2011 01:20 PM |
Window Size | jdjurado | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-15-2009 10:44 PM |
H/W Buffer Size error solution | Brubacher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-29-2004 12:58 PM |
My H/W buffer size problem and solution. | w3ird | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-29-2004 04:19 PM |
window size in 6.1 | matocaster1202 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-13-2003 04:57 PM |
