96 khz recording with 002
i tried to start a new sesion and to start recording in 96khz, but protools made a hissing sound and the message was something about the interenal clock. Can i record in 96 khz and how do i fix the interenal clock problem.
thanks soundlab |
Re: 96 khz recording with 002
First, be a sport and go delete your duplicate of this thread. Then come back and give us more info so we can try to help. If you have any digital devices attached to your 002 via SPDIF or lightpipe, that could be a problem. For troubleshooting purposes, I would disconnect anything for the moment. When you created your session, did you select 24 bit and 96K before clicking OK? Are you creating your session on an audio drive(and not your system drive or a partition on the system drive)? Remember, 96K will make for much larger audio files(as in TWICE as large). If you do have something external patched into SPDIF or lightpipe, SPDIF must be the master clock(lightpipe will not do higher than 48K), so you would go to Hardware setup and select Sync to RCA(SPDIF). If none of this helps, get us more info and don't give up just yet.
thanks, sorry about the 2nd post ,i'm new at this .
i do use a litepipe as well as the other inputs so that i have 16 total inputs . |
you cannot record 96k via lightpipe...
Recording timing / late recording issue resolved | DAWgEAR | Pro Tools HDX & HD Native Systems (Win) | 0 | 07-17-2013 09:10 AM |
low latency recording vs low hardware buffer size recording | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-27-2009 06:49 AM |
Distortion of Recording When Playing Back Recording | acs | Pro Tools M-Powered (Win) | 2 | 03-18-2008 04:29 PM |
PT 5.1 - Recording very lengthy narrative project.. ran out of recording disk space? | Rockman-Songwriter | Pro Tools TDM Systems (Mac) | 6 | 04-16-2003 12:32 AM |
Recording automation AT THE SAME TIME as recording tracks | mikeb37 | Tips & Tricks | 3 | 03-13-2000 09:43 PM |
