Re: 2021.6 EUCon and S1
ah ok! it worked a few days ago, until I updated everything today
PS: it doesn't work with Logic either There too the "lock to Application" are grayed out! Last edited by copesetic; 06-30-2021 at 10:12 AM. |
Re: 2021.6 EUCON and S1
I just installed EUCON 2021.6, updated firmware on my S1 (Galaxy Tab-A) & Dock (iPad Pro), updated the Control app on both tablets - they didn't connect till I did a Restart EUCON Appliations... in the EuControl menu.
S1 doesn't require a tablet to work with PT. Double check that you've enabled EUCON in Setup > Peripherals > Ethernet, and that you have everything on the same network. If that doesn't help... more info please?
• linkedin •
Re: 2021.6 & s1
Uncheck Enable EUCON in Setup > Peripherals... > Ethernet and click OK, then open it again to enable and click OK.
In the EuControl menu (upper right menu bar) select Restart EUCON Applications... and click YES. P.S. What OS version?
• linkedin •
Does in the peripherals setting Ethernet Port:? have to be checked?
#16
ah ok! so I think I did all you said but its still not being seen by PT or logic. only in OS security there is a check for EuControl.app right?
#17
OS Version 11.2.3
EuControl is 2021.6.0.191 EUCON Version 4.7.9.181 The S1 is connected via ethernet cable to a switch and the switch to a thunderbolt Hub S1 FW:21.6.7 |
#18
Similar setup here... S1 & Dock - TP-Link 5-port switch - USB C hub - iMac. I did have to enable the EuControl app in Security & Privacy > Accessibility to start it. Also had to create a new service and add a USB 10/100/1000 LAN in my Network control panel so please check both of these.
• linkedin •
#19
S1 not working with PT since updating PT & EUCON to 2021.6
So… I updated my MBP to 11.4 and what do you know, after starting PT and opening a session, the faders from the S1 moved to their respective positions in the arrangement and it all seems to work again!
Thx for your help! Now I just have to wait for Amazon to update their Avid Control App. Sent from my iPhone using Tapatalk |
#20
Re: S1 not working with PT since updating PT & EUCON to 2021.6
Glad to hear that!
• linkedin •
EUCON 2021.6 Released | EddieJones | Avid S1, S3, Dock and Control App | 56 | 09-22-2021 07:45 AM |
Since updating to 2021.6 wont play | Davidwilson | Pro Tools | 3 | 07-16-2021 07:13 AM |
EUCON 2021.6 Now Available | Avid | Technical Alerts | 0 | 06-29-2021 11:12 AM |
Updating to 2021.3 | Aviator7788 | Pro Tools | 13 | 05-12-2021 01:47 PM |
Missing Ableton Rewire Plugin After updating to PT 2021.3 | Paulienat | Pro Tools | 10 | 03-30-2021 12:50 PM |
