Old 06-26-2021, 03:08 PM
paul_g's Avatar
paul_g paul_g is offline
Default Going back to 2021.3... see other posts
I need to go back to 2021.3, seems there is some kind of memory leak (I can't prove it using analytical tools), but given the lag, choppy click and drags of parameters, and choppiness of the meters etc, I would say there is some kind of issue.
Gotta go back until this one is sorted. I could deal with the tab to transient issues because there was a workaround...
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 06-26-2021, 03:49 PM
paul_g's Avatar
Default Re: Going back to 2021.3... see other posts
I went back to 2021.3 and the issues have disappeared. Basically it seems like it's a slow video issue. If I click on anything and try to drag it, i.e. making a selection on a wave file, trying to change a slider in a parameters window such as the color palette, the mouse is sticky, choppy and jumps.
The Meters on the mix window are choppy and sticky too.
I also see the issue where loading a session, the video of the session takes about 30ms to load. I'm hoping this is all tied to the same bug.
It's been a long time since I've gone backwards in a release, but had to on this one.
For those that are interested here is the case I opened with Avid: 04196098
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Old 06-26-2021, 11:14 PM
Emi's Avatar
Emi Emi is offline
I rolled back too. Hope Avid fixes it soon.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 06-28-2021, 03:43 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Can you open the MacOS Activity Monitor and show the GPU history window and report what it's showing?
Old 06-28-2021, 08:39 AM
Bigbottomend Bigbottomend is offline
Same here. Not a good release. Pity.
Old 06-28-2021, 08:46 AM
dankin dankin is offline
Same here.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII
Old 06-28-2021, 09:01 AM
Ray Lyon Ray Lyon is offline
Originally Posted by dankin View Post
Same here.
Are you still on OS 10.12.6? Could that be a factor?
Old 06-28-2021, 09:05 AM
nebosphere nebosphere is offline
What resolution is your display and what’s the OS/hardware config? Curious if this is related to what I’m seeing.
Old 06-28-2021, 09:17 AM
No...need to update that old signature...on Big Sur 11.4 here, MBP16 with 32 gig of ram. I was on 11.3.1 when I first installed 2021.6, decided to update to 11.4 to see if that would help, but both were really sluggish. I haven't had any crash's, so it's stable in that regard, just annoyingly sluggish like others are reporting. It all seems graphic related. I'm seeing the random black box's appear in the timeline. Also, plugins are responding slow when adjusting parameters.
Old 06-28-2021, 03:25 PM
rinky rinky is offline
Same experience here.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
No SRC in 2021.3.1 JanuS Pro Tools 13 01-11-2022 06:52 AM
external SSD disks will not mount after 2021.6 update mixer Pro Tools 3 06-26-2021 10:44 AM
2021.3.1 innesireinar Pro Tools 80 04-22-2021 01:31 PM
Rolled back to 2020.12 from 2021.3 ejinbc Windows 2 03-27-2021 04:40 PM
