  #21
Old 06-29-2021, 09:51 AM
dankin dankin is offline
Default Re: Going back to 2021.3... see other posts
Originally Posted by nebosphere View Post
Curious to know if you running your display scaled, or at native resolution. I have a 4k monitor and my graphics issues are MUCH worse when I run it scaled. That said, I have to or I can't see anything
2018 Mac mini, 64GB RAM, 2TB SSD, AMD RX 5600 XT eGPU, 4k display using DisplayPort.
Not at the moment, currently using a 27" at it's native 2560X1440 Rez. I did use a 40" 4k scaled for a while as well, but I just moved and went back to my 27. Everything I do with 2021.6 feels slow, even opening the bounce window is slow. I still have 2020.11 installed and it is snappy in comparison. I wonder if it has something to do with the M1 compatibility? The first version of Logic that was M1 compatible was also sluggish on this computer. Similar issues for me, although I think PT is even worse.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII
  #22
Old 06-29-2021, 10:06 AM
paul_g's Avatar
paul_g paul_g is offline
Avid has responded to my case... They want me to create a video of the issue so that tells me they are completely unaware of all these threads out here with multiple people complaining.
Since I've already gone back to 2021.3 I'm going to have to fully uninstall (again) and install 2021.6.
If anyone else can PLEASE create a video and put the link in this thread, it would be greatly appreciated.
I'm not quite sure how i'm going to capture sluggishness with a mouse via video... I can probably do a bunch of actions on 2021.3, then do a video showing same on 2021.6
Again, any help is appreciated.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
  #23
Old 06-29-2021, 10:22 AM
cwsand's Avatar
cwsand cwsand is offline
You shouldn't have to - just change the name of the 2021.3 app and then install 2021.6.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
  #24
Old 06-29-2021, 10:45 AM
paul_g's Avatar
Thanks, I'll give that a shot.
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
  #25
Old 06-29-2021, 01:43 PM
Thank Paul. It is good that Avid is working through this with you and made aware of the issues with the sluggish GUI.
Obsidian Dragon
Mac Studio M1Max - 64GB
  #26
Old 06-29-2021, 02:01 PM
paul_g's Avatar
UPDATE:
When I upgraded to 2021.6 from .3, I just did an upgrade install. I never cleanly removed the previous version.
While making the videos, I decided I would do one video while I was still on 2021.3 to show everything working fine.
Despite taking some shortcuts and just renaming the Pro Tools app, and installing 2021.6;
1.) I decided to do a complete uninstall of 2021.3 following Avid's instructions and then rebooted my iMac:
https://avid.secure.force.com/pkb/ar...uninstall-PT11
NOTE: BE SURE TO BACKUP YOUR PLUGINS...
2.) I did a complete fresh install of PT 2021.6 and then rebooted my iMac after. I launched PT and accepted the "install Helper"
3.) I recovered my plugins from a backup.
All issues went away. The only sticky movement was the sliders on the new Color Palette. The meters were no longer choppy, edit selection within a track was smooth...
So my suggestion to everyone having issues is please do a clean uninstall, (make sure you backup your Plugs), and reinstall cleanly and restore your plugs.
I'm going to stay on 2021.6 now considering it's running smoothly and I will update Avid accordingly
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
  #27
Old 06-29-2021, 02:36 PM
UPDATE:
Nice! I will give that a try as well.
  #28
Old 06-29-2021, 02:39 PM
paul_g's Avatar
Good! I'm eager to hear how it goes, please let us know!
Internal 2TiB SSD
Pro Tools 2024.3
UA Luna
UAD 11
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
  #29
Old 06-29-2021, 04:47 PM
Ok. Did the uninstall, and reinstalled only 2021.6. It is better for sure. No spinning beach ball yet, still not as snappy as previous versions. Also, still seeing the black boxes occasionally.
  #30
Old 06-29-2021, 06:01 PM
Spoke to soon...the beachballs are back. Happens when adjusting plugins, scrolling the mixer, doing edits, etc.
No SRC in 2021.3.1 JanuS Pro Tools 13 01-11-2022 06:52 AM
external SSD disks will not mount after 2021.6 update mixer Pro Tools 3 06-26-2021 10:44 AM
2021.3.1 innesireinar Pro Tools 80 04-22-2021 01:31 PM
Rolled back to 2020.12 from 2021.3 ejinbc Windows 2 03-27-2021 04:40 PM
