Low latency
How is the best way to have low latency monitoring with m-audio sound card's? Thanks
Core2DuoE6600|P5W-DH|4GBddr2TeamGroup|7300GT256mb|BeQuiet700w|Cubase 4.1.3|Protools M-Power7.4|2xUAD-1ApogeeRosetta200|M-Audio1814|RME FF800|G5 8core |
Re: Low latency
Hum?
Re: Low latency
if the lowest buffer setting available to u is not low enough for you, switch to hardware direct monitoring, refer to the interface manual for this. MP does not have the 'low latency' settings of LE, and i find the lowest available not good enough for live tracking.
Cheers! Sidhu
Hp Probook 4530s. i3 Sandy. 4gig RAM TI/VIA Firewire expresscards. |
Re: Low latency
Most M-Audio interfaces have a "no" latency mixer. This means having to switch between the mixer application and Pro Tools. You can run them both at the same time, and switch between them using the "Start bar" at the bottom of the screen.
1. Record enable a track in Pro Tools. 2. Mute the track. 3. Unmute the channel in the M-Audio mixer application. 4. Record the track while monitoring through the M-Audio mixer. 5. Unmute the Pro Tools track and listen to playback. I like to use a little reverb for tracking vocals, so you can set up a reverb-only aux input. 1. Create an aux track. 2. Assign it's input to the hardware input you want to record. 3. Instantiate a reverb plugin, setting it to 100% wet. 4. Adjust level accordingly. You'll get some buffer delay, but it shouldn't be noticeable with an effect like reverb. This won't work with "dry" effects like compression. Punch-ins are another story, but possible using two tracks and the "no" latency M-Audio mixer. 1. Assign your already recorded track input to an unused input (silence). 2. Create a new track with it's input assigned to the correct source. 3. Put Pro Tools in to "Punch Record" mode. 4. Record enable BOTH tracks. 5. Leave the original track unmuted, but mute the new track. 6. Punch in where necessary. The old track has silence punched in, the new track has the real punch. 7. Drag the new punched clip over the old track. You may have to do some tidying up after all those clips of silence, but if they're not part of the track you can have Pro Tools delete them as unused audio. Somebody may have a better way to do it, but this works for me. Hope it helps. |
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Piano VI's- Latency Latency!! | MARVINBASS | Virtual Instruments | 5 | 04-27-2006 01:09 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
